I have two GEM and have some odd issues with both of them from the voltage monitor.
For Unit #1, I occasionally record improbably low or impossibly high values:
> SELECT "volts" FROM "voltage" WHERE ("serial" =~ /^01120860$/) AND time >= 1663625927152ms and time <= 1663625951873ms fill(null);
time volts
1663625928000000000 121.8
1663625930000000000 121.8
1663625932000000000 121.6
1663625934000000000 121.7
1663625936000000000 121.7
1663625938000000000 121.7
1663625940000000000 121.7
1663625942000000000 121.7
1663625944000000000 121.8
1663625946000000000 11.8
1663625948000000000 121.7
1663625950000000000 121.7
> SELECT "volts" FROM "voltage" WHERE ("serial" =~ /^01120860$/) AND time >= 1662020921000000000 and time <= 1662020935000000000;
time volts
1662020921000000000 121.8
1662020923000000000 121.8
1662020925000000000 121.8
1662020927000000000 1218
1662020929000000000 121.8
1662020931000000000 121.8
1662020933000000000 121.8
1662020935000000000 121.8
I have a 2nd GEM unit which also shows this issue, but, in addition to that all values are implausibly low:
> SELECT "volts" FROM "voltage" WHERE ("serial" =~ /^01120861$/) AND time >= 1662020921000000000 and time <= 1662020935000000000;
time volts
1662020921000000000 68.9
1662020922000000000 68.9
1662020923000000000 68.8
1662020924000000000 68.8
1662020925000000000 68.8
1662020926000000000 68.8
1662020927000000000 68.8
1662020928000000000 68.8
1662020929000000000 68.8
1662020930000000000 68.8
1662020931000000000 68.8
1662020932000000000 68.8
1662020933000000000 68.8
1662020934000000000 68.8
1662020935000000000 68.8
