Post
by ben » Thu Feb 22, 2018 10:47 am
topherhansen wrote:On the Ethernet Only tab I can click search and it finds the GEM. I clicked Server on Ethernet Mode and clicked Save Settings. Its has a "Processing" progress bar and then announces "Saved Successfully".
You did it here, your TCP Client connection is right. Click Open and make sure the top-right says "Connected." and is green.
If that works, then just follow the instructions in my first post to load the firmware. Go straight to the latest COM version (4.33).
topherhansen
Post
by topherhansen » Fri Feb 23, 2018 12:45 am
When I click Connect it just gives me an alert that says "Could not connect!"
- could not connect.png (236.63 KiB) Viewed 1964 times
Post
by ben » Fri Feb 23, 2018 11:22 am
topherhansen wrote:Are you sure the power supplies I have are good enough? Mine says 5V 500mA. But the
http://www.brultech.com/contact/ page says I need 2000mA.
I mean this used to work for like a year.
500mA is fine for the GEM. The 2A is for the DashBox.
What happens if you switch it to DHCP instead of Static? What IP address does it get assigned?
topherhansen
Post
by topherhansen » Fri Feb 23, 2018 11:53 am
When I click DHCP and save it says it saves successfully but then when I hit search again it shows the same IP and that it switched back to static.
I don't see any conflicts on the router for the same IP address.
Post
by ben » Fri Feb 23, 2018 12:16 pm
topherhansen wrote:When I click DHCP and save it says it saves successfully but then when I hit search again it shows the same IP and that it switched back to static.
I just noticed the F/W version (the 82.0 number). It looks like the modules F/W may have gotten corrupted.
Download this program here:
http://www.wiznet.io/wp-content/uploads ... Config.zip
And this firmware here:
http://www.wiznet.io/wp-content/uploads ... r_0513.zip (the bin file inside the zip).
Try updating the firmware on the Ethernet module using the program above.
topherhansen
Post
by topherhansen » Fri Feb 23, 2018 10:00 pm
It Connected!
Thanks. The ethernet module is up to 5.13 now.
topherhansen
Post
by topherhansen » Fri Feb 23, 2018 10:20 pm
So I tried to update the COM to 4.33. It seemed to work.
Now I can call GET Gem Info.
An alert shows up:
GEM Network Utility
Refresh error 2 0
Response data = ¼lüJT*tœ:¾+J–+J–+J–ËË–ËË–ëË–ë˶«Êž™
Data Length = 40
OK
And it says it can't get the GEM serial number.
Requesting GEM Serial Number...... FAIL
Reading settings.......OK
Reading hardware ........OK
Completed
Attempts to update the ENG at this point don't work.
So I switched the baud rate to 115200. This was able to connect and get gem info without issue.
But when I attempted to update the ENG firmware it said I had to switch back to 19200
If I do attempt to update the ENG when at 19200 (with the mixed success/error) it gives me this alert:
GEM Network Utility
No response from the GEM....... Now exiting
OK
- get gem info.png (268.85 KiB) Viewed 1942 times
topherhansen
Post
by topherhansen » Fri Feb 23, 2018 10:32 pm
Here is get info if it's set to 115200 baud
- 115200 baud get info.png (311.74 KiB) Viewed 1941 times
topherhansen
Post
by topherhansen » Fri Feb 23, 2018 10:35 pm
OK, I got it. On the Firmware tab I clicked the 19200 baud and then switched to ethernet and switched it to match.
- upgraded done.png (215.29 KiB) Viewed 1940 times
