Hello,
I am running two GEMs and collecting data using standalone dashboard.
For one GEM, I retrieved data by using "SELECT * FROM `minutedata` WHERE channel_id=x;" query in phpMyAdmin.
However, how can I separate each GEM's data from the same table?
I can find only one `minutedata` table in `dashboard` database. There is `devices` table, but no foreign key was found in `minutedata` from the `devices` table.
I think I can add foreign key on database, but I guess the data is already separated because when I looked at the line graph in each GEM, the two GEM's data are separated.
Thanks for the answers!
multiple GEM identifier in standalone dashboard
- erd.png (259.95 KiB) Viewed 1566 times
Re: multiple GEM identifier in standalone dashboard
ecosang wrote:Hello,
This will give you all channels that belong to one GEM (replace X's with Serial).
SELECT * FROM channel
INNER JOIN devices.device_id = channel.device_id
WHERE serial = XXXXXXX;
SELECT * FROM minutedata
INNER JOIN channel ON channel.channel_id = minutedata.channel_id
INNER JOIN devices.device_id ON devices.device_id = channel.channel_id
AND date BETWEEN 'START' AND 'END';
