Issue receiving data on Standalone Dashboard
rgstech
Post by rgstech » Sun May 14, 2017 8:49 am
I recently updated the firmware on my GEM to COM firmware ver: 4.33, ENG firmware ver: 1.49. After the update, I am no longer receiving data on the Standalone Dashboard. If I look at live data on the GEM, all channels are displaying correct data. However, if I look at raw data on the Standalone Dashboard, it appears only the temperature channel is being received.
2017-05-14 08:42:24: Serial Number is 01100xxx and seconds is 1403172
01100337 Debug
Pulse: 0,0,0,0
Wattseconds: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-14 08:43:07: Serial Number is 01100xxx and seconds is 1402572
01100337 Debug
Pulse: 0,0,0,0
Temps: 73.0,,,,,,,
2017-05-14 08:43:08: Serial Number is 01100xxx and seconds is 1403742
01100337 Debug
Pulse: 0,0,0,0
Temps: 73.0,,,,,,,
2017-05-14 08:45:25: Serial Number is 01100xxx and seconds is 1404552
01100337 Debug
Pulse: 0,0,0,0
Temps: 73.0,,,,,,,
Any suggestions on how to further troubleshoot?
Rob
Re: Issue receiving data on Standalone Dashboard
Post by ben » Mon May 15, 2017 10:25 am
Those WS values show 0 here also with proper data coming in.
Are they charting the correct values? If so, you're good to go.
rgstech
Post by rgstech » Mon May 15, 2017 6:42 pm
Previously I was getting 0 values across the board, nothing was charting.
I changed the IP addresses on the GEM network tab, and then changed it back to the correct value for the Dashboard.
Now I'm getting some data. I get correct values, then 0 values, then correct values. My charts are all skewed, as it keeps plotting 0 values between real data.
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:30:33 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 0)(e_1 0)(p_2 0)(e_2 0)(p_3 0)(e_3 0)(p_4 0)(e_4 0)(p_5 0)(e_5 0)(p_6 0)(e_6 0)(p_7 0)(e_7 0)(p_8 0)(e_8 0)(p_9 0)(e_9 0)(p_10 0)(e_10 0)(p_11 0)(e_11 0)(p_12 0)(e_12 0)(p_13 0)(e_13 0)(p_14 0)(e_14 0)(p_15 0)(e_15 0)(p_16 0)(e_16 0)(p_17 0)(e_17 0)(p_18 0)(e_18 0)(p_19 0)(e_19 0)(p_20 0)(e_20 0)(p_21 0)(e_21 0)(p_22 0)(e_22 0)(p_23 0)(e_23 0)(p_24 0)(e_24 0)(p_25 0)(e_25 0)(p_26 0)(e_26 0)(p_27 0)(e_27 0)(p_28 0)(e_28 0)(p_29 0)(e_29 0)(p_30 0)(e_30 0)(p_31 0)(e_31 0)(p_32 0)(e_32 0)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 121.7)))
2017-05-15 18:30:33: Serial Number is 01100337 and seconds is 1527022
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:31:03 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 0)(e_1 0)(p_2 0)(e_2 0)(p_3 0)(e_3 0)(p_4 0)(e_4 0)(p_5 0)(e_5 0)(p_6 0)(e_6 0)(p_7 0)(e_7 0)(p_8 0)(e_8 0)(p_9 0)(e_9 0)(p_10 0)(e_10 0)(p_11 0)(e_11 0)(p_12 0)(e_12 0)(p_13 0)(e_13 0)(p_14 0)(e_14 0)(p_15 0)(e_15 0)(p_16 0)(e_16 0)(p_17 0)(e_17 0)(p_18 0)(e_18 0)(p_19 0)(e_19 0)(p_20 0)(e_20 0)(p_21 0)(e_21 0)(p_22 0)(e_22 0)(p_23 0)(e_23 0)(p_24 0)(e_24 0)(p_25 0)(e_25 0)(p_26 0)(e_26 0)(p_27 0)(e_27 0)(p_28 0)(e_28 0)(p_29 0)(e_29 0)(p_30 0)(e_30 0)(p_31 0)(e_31 0)(p_32 0)(e_32 0)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 121.4)))
2017-05-15 18:31:03: Serial Number is 01100337 and seconds is 1527052
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 18:31:03: Serial Number is 01100337 and seconds is 1527172
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:32:04 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 15896)(e_1 662.34)(p_2 520)(e_2 21.68)(p_3 2309)(e_3 96.2)(p_4 257)(e_4 10.71)(p_5 570)(e_5 23.74)(p_6 3494)(e_6 145.57)(p_7 0)(e_7 0.02)(p_8 341)(e_8 14.2)(p_9 0)(e_9 0.02)(p_10 14)(e_10 0.58)(p_11 6)(e_11 0.25)(p_12 60)(e_12 2.51)(p_13 2)(e_13 0.06)(p_14 0)(e_14 0.01)(p_15 2)(e_15 0.1)(p_16 5)(e_16 0.21)(p_17 3)(e_17 0.14)(p_18 0)(e_18 0)(p_19 109)(e_19 4.52)(p_20 0)(e_20 0)(p_21 634)(e_21 26.42)(p_22 3101)(e_22 129.23)(p_23 927)(e_23 38.64)(p_24 10)(e_24 0.43)(p_25 7)(e_25 0.3)(p_26 6)(e_26 0.23)(p_27 97)(e_27 4.04)(p_28 1)(e_28 0.04)(p_29 8)(e_29 0.34)(p_30 2606)(e_30 108.6)(p_31 685)(e_31 28.56)(p_32 30)(e_32 1.24)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 121.45)))
2017-05-15 18:31:34: Serial Number is 01100337 and seconds is 1527082
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 18:32:04: Serial Number is 01100337 and seconds is 1527202
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:33:04 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 15836)(e_1 131.97)(p_2 521)(e_2 4.34)(p_3 2306)(e_3 19.21)(p_4 253)(e_4 2.11)(p_5 567)(e_5 4.73)(p_6 3465)(e_6 28.88)(p_7 0)(e_7 0)(p_8 350)(e_8 2.92)(p_9 1)(e_9 0.01)(p_10 14)(e_10 0.12)(p_11 6)(e_11 0.05)(p_12 59)(e_12 0.49)(p_13 2)(e_13 0.01)(p_14 0)(e_14 0)(p_15 2)(e_15 0.02)(p_16 5)(e_16 0.04)(p_17 3)(e_17 0.03)(p_18 0)(e_18 0)(p_19 108)(e_19 0.9)(p_20 0)(e_20 0)(p_21 640)(e_21 5.33)(p_22 3099)(e_22 25.83)(p_23 924)(e_23 7.7)(p_24 10)(e_24 0.08)(p_25 7)(e_25 0.06)(p_26 6)(e_26 0.05)(p_27 97)(e_27 0.81)(p_28 1)(e_28 0.01)(p_29 8)(e_29 0.07)(p_30 2593)(e_30 21.61)(p_31 685)(e_31 5.71)(p_32 30)(e_32 0.25)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 121.55)))
2017-05-15 18:32:34: Serial Number is 01100337 and seconds is 1527112
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 18:33:04: Serial Number is 01100337 and seconds is 1527232
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:34:04 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 15835)(e_1 131.96)(p_2 521)(e_2 4.34)(p_3 2307)(e_3 19.22)(p_4 253)(e_4 2.11)(p_5 568)(e_5 4.73)(p_6 3460)(e_6 28.84)(p_7 0)(e_7 0)(p_8 342)(e_8 2.85)(p_9 1)(e_9 0)(p_10 14)(e_10 0.12)(p_11 6)(e_11 0.05)(p_12 59)(e_12 0.49)(p_13 2)(e_13 0.01)(p_14 0)(e_14 0)(p_15 2)(e_15 0.02)(p_16 5)(e_16 0.04)(p_17 3)(e_17 0.03)(p_18 0)(e_18 0)(p_19 109)(e_19 0.91)(p_20 0)(e_20 0)(p_21 639)(e_21 5.32)(p_22 3099)(e_22 25.83)(p_23 925)(e_23 7.71)(p_24 10)(e_24 0.08)(p_25 7)(e_25 0.06)(p_26 6)(e_26 0.05)(p_27 97)(e_27 0.81)(p_28 1)(e_28 0.01)(p_29 8)(e_29 0.07)(p_30 2598)(e_30 21.65)(p_31 688)(e_31 5.74)(p_32 29)(e_32 0.25)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 121.5)))
2017-05-15 18:34:04: Serial Number is 01100337 and seconds is 1527262
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 18:34:31: Serial Number is 01100337 and seconds is 1527442
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:35:05 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 12684)(e_1 739.88)(p_2 525)(e_2 30.61)(p_3 2308)(e_3 134.65)(p_4 255)(e_4 14.89)(p_5 568)(e_5 33.13)(p_6 633)(e_6 36.94)(p_7 1)(e_7 0.03)(p_8 343)(e_8 20.02)(p_9 1)(e_9 0.03)(p_10 14)(e_10 0.81)(p_11 6)(e_11 0.34)(p_12 60)(e_12 3.5)(p_13 2)(e_13 0.09)(p_14 0)(e_14 0.01)(p_15 2)(e_15 0.13)(p_16 5)(e_16 0.3)(p_17 3)(e_17 0.2)(p_18 0)(e_18 0)(p_19 108)(e_19 6.29)(p_20 0)(e_20 0)(p_21 228)(e_21 13.31)(p_22 3099)(e_22 180.78)(p_23 928)(e_23 54.16)(p_24 10)(e_24 0.6)(p_25 7)(e_25 0.42)(p_26 6)(e_26 0.33)(p_27 98)(e_27 5.69)(p_28 1)(e_28 0.05)(p_29 8)(e_29 0.48)(p_30 2618)(e_30 152.72)(p_31 685)(e_31 39.99)(p_32 30)(e_32 1.74)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 121.45)))
2017-05-15 18:34:34: Serial Number is 01100337 and seconds is 1527292
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 18:35:05: Serial Number is 01100337 and seconds is 1527472
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 18:35:35: Serial Number is 01100337 and seconds is 1527322
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:36:35 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 0)(e_1 0)(p_2 0)(e_2 0)(p_3 0)(e_3 0)(p_4 0)(e_4 0)(p_5 0)(e_5 0)(p_6 0)(e_6 0)(p_7 0)(e_7 0)(p_8 0)(e_8 0)(p_9 0)(e_9 0)(p_10 0)(e_10 0)(p_11 0)(e_11 0)(p_12 0)(e_12 0)(p_13 0)(e_13 0)(p_14 0)(e_14 0)(p_15 0)(e_15 0)(p_16 0)(e_16 0)(p_17 0)(e_17 0)(p_18 0)(e_18 0)(p_19 0)(e_19 0)(p_20 0)(e_20 0)(p_21 0)(e_21 0)(p_22 0)(e_22 0)(p_23 0)(e_23 0)(p_24 0)(e_24 0)(p_25 0)(e_25 0)(p_26 0)(e_26 0)(p_27 0)(e_27 0)(p_28 0)(e_28 0)(p_29 0)(e_29 0)(p_30 0)(e_30 0)(p_31 0)(e_31 0)(p_32 0)(e_32 0)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 122.45)))
2017-05-15 18:36:35: Serial Number is 01100337 and seconds is 1527352
01100337 Debug
Pulse: 0,0,0,0
Temps: 74.0,,,,,,,
2017-05-15 06:37:06 PM SmartEneryGroups (site cb78569317ca8a2 (node 01100337 ? (p_1 0)(e_1 0)(p_2 0)(e_2 0)(p_3 0)(e_3 0)(p_4 0)(e_4 0)(p_5 0)(e_5 0)(p_6 0)(e_6 0)(p_7 0)(e_7 0)(p_8 0)(e_8 0)(p_9 0)(e_9 0)(p_10 0)(e_10 0)(p_11 0)(e_11 0)(p_12 0)(e_12 0)(p_13 0)(e_13 0)(p_14 0)(e_14 0)(p_15 0)(e_15 0)(p_16 0)(e_16 0)(p_17 0)(e_17 0)(p_18 0)(e_18 0)(p_19 0)(e_19 0)(p_20 0)(e_20 0)(p_21 0)(e_21 0)(p_22 0)(e_22 0)(p_23 0)(e_23 0)(p_24 0)(e_24 0)(p_25 0)(e_25 0)(p_26 0)(e_26 0)(p_27 0)(e_27 0)(p_28 0)(e_28 0)(p_29 0)(e_29 0)(p_30 0)(e_30 0)(p_31 0)(e_31 0)(p_32 0)(e_32 0)(temperature_1 74)(temperature_2 0)(n_1 0)(n_2 0)(n_3 0)(n_4 0)(v_1 122.3)))
2017-05-15 18:36:35: Serial Number is 01100337 and seconds is 1527502
01100337 Debug
Pulse: 0,0,0,0
Temps: 73.0,,,,,,,
Post by ben » Tue May 16, 2017 9:25 am
What firmware did you upgrade from?
If it was before the 4 series, I'd suggest doing a factory reset under the Firmware tab and setting the GEM back up. We've had issues in the past with older firmware messing up some settings.
Under the Adv page in the GEM Web Setup make sure that your settings are similar to the attached settings.
It's important to make sure Flow Control is disabled as that can cause lockups when streaming data if you're using our communication modules.
2017-05-16 10_23_18-GEM Setup.png (61.57 KiB) Viewed 2973 times
rgstech
Post by rgstech » Tue May 16, 2017 3:15 pm
Ben - Thanks for your help.
Upgraded from 4.22.
All my settings on that page are the same except I have Reset Wh on Post set to disabled.
Post by ben » Wed May 17, 2017 10:05 am
rgstech wrote:Ben - Thanks for your help.
Upgraded from 4.22.
Ahh, that'll be your issue right there.
kWh are based on delta wattseconds (difference between this packet and your last packet). If you're resetting Wh every post, it's going to mess up as it'll detect a rollover every time. When it rolls over, your delta calculation turns into:
256^5-Prev WS+Current WS
The Standalone will detect this as a fault and throw the packet away.
rgstech
Post by rgstech » Wed May 17, 2017 10:20 am
Sweet. Let me make that change and I'll let you know how it goes.
rgstech
Post by rgstech » Thu May 18, 2017 12:38 pm
Made the change, still having pretty regular 0 watt data.
Post by ben » Thu May 18, 2017 3:49 pm
Did you reboot the COM firmware after? I'd do that to make sure it took hold.
Can you post your other settings screens on the GEM? I'll look through for issues.
rgstech
Post by rgstech » Thu May 18, 2017 6:50 pm
I did reboot after the COM firmware upgrade. I have completely powered off and power back on a couple of times since.
