Cant connect to my GEM
daudet
Contact:
Post by daudet » Fri Dec 16, 2016 11:49 am
Hi , Just got my Dashbox and trying to access GEM.
earlier with the old GEM Util Network
i was able to.
but after trying to configure GEM to send data to DB and cant get access anymore.
PING is ok but with new GEM util Ver 7.0
i have still have to check mark USe Direc Ip search and it get back to me with Could not connect to 192.168.1.112 port 1461
What is the next step.
Also is someone could post a screen shot on how to setup in GEM it would be appreciated.
In the Dashbox in Energy Monitor Option i dont have Add a monitor Only Remove a Monitor
What is the Issue. Should i ask in the Dashbox support for this question.
Regards
Daniel Audet VA2DG
Re: Cant connect to my GEM
Post by Teken » Fri Dec 16, 2016 12:17 pm
Holy crap Daniel where have you been my friend! If you have Skype perhaps we can get you going a little faster?
Post by ben » Fri Dec 16, 2016 12:21 pm
There's no more Add A Monitor as it'll detect it once the first packet comes in.
Do you have the Ethernet module set to Mixed mode? Try setting it to Server mode then connecting to it. If that works, then your connection is being held by the DashBox (which means you should just have to lower the idle time, try 2 seconds).
-The GEM has to be configured for HTTP Get under Packet Send.
-Standalone Dashboard/DashBox under Data Post.
In the GEM Network Utility,
-Server IP to DashBox IP
-Remote Port to 80.
-Preferably Mixed mode, but you can use Client temporarily for testing.
daudet
Contact:
Post by daudet » Fri Dec 16, 2016 2:08 pm
Well Ben i canot even talk to Gem ethernet module i get a popup with
son nothing populate in thé network. utility.
Daniel Audet VA2DG
Post by ben » Fri Dec 16, 2016 2:12 pm
daudet wrote:Well Ben i canot even talk to Gem ethernet module i get a popup with
Can you check your router to make sure it's still being assigned an IP address? Also, check the status LEDs and Ethernet jack lights on the GEM.
Also check the power supply versus the notice here: http://brultech.com/contact
daudet
Contact:
Post by daudet » Fri Dec 16, 2016 3:44 pm
Ok Status LED on GEM both Green with left one flashing Red every 30 sec approx.
Ethernet LED are of and respond to the steady Ping.
Effectively the PS is the OLD 1500ma type and i just used the DB PS which is the new model and will see if it works.
Ok when it got back up the ip did change from .112 to .118
i can ping no problem but still cant connect
Look at the Device Discovery, it did discover it. Double clic on it get me to the web browser but it time out and nothing. also on device discovery i have the wrong PC IP. 192.168.56.1 Dont know where the hell it is coming from..
Also the err_connect mean that it is not in server mode but without access to Net Util i cant change it.
Device discovery
Device discovery
12-16-2016 3-34-40 PM.jpg (60.18 KiB) Viewed 2634 times
Then running GEM Network Utility i have to check Use Direct IP seard and i get the popup that port 1461 is not .
12-16-2016 3-36-33 PM.jpg (117.29 KiB) Viewed 2634 times
Daniel Audet VA2DG
daudet
Contact:
Post by daudet » Fri Dec 16, 2016 11:20 pm
Finally got it.
I ran Net Util from my Toughbook and on first scan it found the GEM
i put the DB IP in and save and when back to DB and used a temporary DLINK 5vdc 2amp PS to power it up as the original was put on the GEM earlier.
then when i logged it the DB i got the GEM that was waiting for me.. but still can't get on GEM with WEB browser. but at least the data is coming in the DB.
16-Dec-16 11-15-26 PM.png (16.9 KiB) Viewed 2624 times
Daniel Audet VA2DG
daudet
Contact:
Post by daudet » Sat Dec 17, 2016 8:47 am
Thank Ben for your input,
now will configure the unit.
Question?
When i will find a 128gb card can i backup the existing and restore on the new one so i dont loose my info.
Daniel Audet VA2DG
Post by Teken » Sat Dec 17, 2016 8:50 am
Yes
Post by ben » Mon Dec 19, 2016 10:48 am
daudet wrote:Thank Ben for your input,
Question?
Yeah, you'll need my help currently to expand the SD card to the full capacity however.
