1-Wire Sensors
Re: 1-Wire Sensors
If you scanned older threads many of the things you indicated were listed in the new feature requests for the product. Like you I also determined that using a 3rd party 1 wire module was required and thus went with Autelis because it offered the tight integration I needed for my entire home automation system.
Re: 1-Wire Sensors
Yes, that's what I was referring to, all the older requests. Wondering what the status on those is, if any. Most particularly increasing the number of temp sensors. Any progress on that front Brultech?Teken wrote:If you scanned older threads many of the things you indicated were listed in the new feature requests for the product. Like you I also determined that using a 3rd party 1 wire module was required and thus went with Autelis because it offered the tight integration I needed for my entire home automation system.
And, IF it was implemented, would it require changes to the hardware, or could it be pushed out in firmware alone?
If it was in the pipeline as a firmware update that would encourage me to buy a GEMS sooner rather than later. (I compared carefully with a TEDPro/5000 -- the accuracy on the TED series seems to be a bad joke, they offer only +/- 7% on average, "5% with calibration," and a minimum wattage reading (on their smallest coil) of 60 watts!)
A bit off-topic:
Re: Home automation (HA) -- I've chosen to go with OpenHAB for home automation, due to zero software cost and maximum flexibility / hackability. I've read about well-developed OpenHAB interfaces / hooks for the GEMS, will post here if /when I get a GEMS working w/ OpenHAB.)
I particularly like OpenHAB because it is hardware-agnostic, you can pick & choose what works best for you -- CPU speed vs. power& heat trade offs, storage, RAM, types & numbers of ports, etc. And, being hardware agnostic it is easier to troubleshoot in public-forum setting because the bulk of the troubleshooting is *in the public code repository,* not in proprietary firmware.
I strongly considered MiCasaVerde early on but after reading through their forums I realized it was a total nightmare because everything depends on the opaque & apparently poorly-maintained MCV firmware.
Re: 1-Wire Sensors
My understanding is the eight 1 wire for the GEM in its current form is the limit. I believe going the route via openHAB is most excellent but for those looking for a plug and play approach that eliminate most casual users.
Re: 1-Wire Sensors
We won't be able to increase the amount of temperature sensors the GEM supports unfortunately. The 1-wire and pulse count are controlled by the same processor.gosmond wrote: Yes, that's what I was referring to, all the older requests. Wondering what the status on those is, if any. Most particularly increasing the number of temp sensors. Any progress on that front Brultech?
If you want to run a bunch of 1-wire temperature sensors, a 3rd party solution is the best way to go as you're likely to get a higher resolution out of them also.
In hindsight, if we knew temperature was going to pick up like it did, we would've implemented it differently.
Re: 1-Wire Sensors
Thanks for the update.ben wrote: ...
I'm going with the OW-SERVER product from Embedded Data Systems. Relatively cheap at ~$100, built-in web interface, open API, supports up to 22 (twenty two) 1-Wire devices, also well-supported by OpenHAB.
Side note: 22 devices is still on the low side for my taste, EDS also makes the HA7NET product, an older item that supports up to about 100 devices. But the HA7NET firmware is no longer being updated and it is not well-supported in OpenHAB.
Re: 1-Wire Sensors
Teken, can you clarify for me please...
I have an existing energy monitor on my geothermal system called "ewise". I don't think it is supported anymore - although I still pay a site to host the data that it pushes out. It is inaccurate on the power monitoring side but good on the temp monitoring side.
I am in the process of replacing it with a GEM (power part for all circuits in the house is done - see attached picture). Now I want to migrate the 8 temp sensors (outside air temp, 5-foot ground temp, ground water loop in/out, HVAC supply air temp in/out, and hot water boost temp in/out) to the GEM. So I've essentially got an existing 1-wire network. I can use an arduino to get the addresses of each sensor using code I found on the emonx (sp?) site, and with the data coming from each I can figure out which is which.
So what do you guys mean when you say enroll them one at a time? Do I have to physically disconnect all but the sensor being enrolled, or can I enter an address, one at a time, into the GEM and go from there? Hopefully so because it will be a pain to physically disconnect each sensor
Thanks in advance. I sincerely appreciate all the advice you have given me.
Joe Kubinec
Hollywood, Maryland
Joe Kubinec
Hollywood, Maryland
- IMG 20161224 173315.jpg (537.66 KiB) Viewed 2202 times
Re: 1-Wire Sensors
Hello Joe,
You sure can enter the MAC address of the 1 wire sensor if its known into the GEM. I would highly suggest you copy and paste the MAC address value instead of typing them in to save time and ensure accuracy of the value(s).
Merry X-MAS!
Merry X-MAS!
