ECM-1240 Device Serial Number = 0-00000
Hi, everybody i have 3 ecm´s 1240, im reading them through one serial rs232. Then i need to
differentiate each of them with the serial number but two of them appears like 0-00000. why ?? and
how can i fix it?
Thanks!!!
how can i fix it?
Thanks!!!
Re: ECM-1240 Device Serial Number = 0-00000
How old are these monitors? Do they have a serial number on the back of them?ECMBonilla wrote:Hi, everybody i have 3 ecm´s 1240, im reading them through one serial rs232. Then i need to
how can i fix it?
Thanks!!!
Are you using our IA software to read the serial numbers?
They are like 4 years old. They (all of them) have a sticker in front with a serial number, any
devices have serial numbers in back. Im using IA and Engine Software to show/view data and the
serial number. Only one! shows same serial number with its sticker, other 2 shows 0-0000. Its
strange i know, i have been reload firmware 1.030 but nothing. You know how can i fix it?
I don't own a ecm1240, I own a GEM, but am wondering
In my 35 years around computers, I never heard you could put more than one device on an RS-232 line, RS-485 yes, but not RS-232
Have you tried the 3 one at a time ??
Just my thoughts
...Barry
Just my thoughts
...Barry
No, only one at time. ......can i configure that?...guess i can not ideas?
Sent over a couple of emails to the address assigned to your account.ECMBonilla wrote:No, only one at time. ......can i configure that?...guess i can not ideas?
Good morning. Recently this has happened to me. I had a power outage and when the unit came back online I had to reconfigure it. The serial number was zero'ed out and the unit number went from unit 1 to unit 0.
Is there a battery in the unit which may need replacing after a time? My unit is probably 4 years old as well.
- Mark.
- Mark.
There's no battery in the unit.mgandalf wrote:Good morning. Recently this has happened to me. I had a power outage and when the unit came back online I had to reconfigure it. The serial number was zero'ed out and the unit number went from unit 1 to unit 0.
- Mark.
Emailed you over a new F/W and sent over an IA version to reprogram the S/N. That should fix up your issue.
Thanks, Ben. I really appreciate that. However, I haven't received your email. I'm assuming you sent it to the address I registered with this forum? I checked my spam folder as well.ben wrote:There's no battery in the unit.
Thanks, Mark.
Yeah, I sent it to that address. It had 2 files attached so it might take some time to go through. If it doesn't reach you in an hour or so let me know and I'll resend. The email might've hit some sort of filter as the zip contains an executable.mgandalf wrote:Thanks, Ben. I really appreciate that. However, I haven't received your email. I'm assuming you sent it to the address I registered with this forum? I checked my spam folder as well.ben wrote:There's no battery in the unit.
Thanks, Mark.
