I have an older ECM-1240 that I am trying to upgrade to the newest firmware to utilize the hardware with a recently purchased Dashbox.
Using the Firmware Updater in IA and following the instructions, I have been unsuccessful on several occasions.
The error message is:
"Could note locate Firm.com files. Would you like to browse for it? Try the ECM-1240 folder."
Upon selecting yes and navigating to the "Firm" file in the Program Files (x86)/Brultech/ECM-1240 Enginer/ directory, it says "Did not locate "Firm.com" file. Aborting Firmware Function"
I have used a couple serial converters, including the TrippLite, with the same results.
Any help would be appreciated. Thanks!
- Ryan
ECM-1240 F/W upgrade issue
Re: ECM-1240 F/W upgrade issue
The issue is the program doesn't have permissions to access the program files folder.TheOtherOne wrote: ↑Mon May 15, 2023 10:17 pmHello,
- Ryan
Copy the Firm.com file to a folder outside of Program Files or right-click and go to "Run as Administrator" and it should go.
Ben,
Thanks for the prompt reply.
This solved the issue and the ECM-1240 firmware was upgraded!
Thank you
- Ryan
Thank you
- Ryan
