I will be needing to power-down my GEM in the future to make some changes. So, is there a safe procedure to follow when shutting down the GEM.
My thoughts are to:
1 - Disconnect the AC transformer used to monitor the AC voltage
2 - Disconnect the 5VDC GEM power source
I do not think that the link to the DashBox needs to be disconnected.
Is there anything else? I am not to worried, as the firmware should not be affected, but just thought that I would ask.
SAFE - Shut down of the GEM
Don
Tell me and I will forget. Show me and I may remember. Involve me and I will understand.
Benjamin Franklin
Benjamin Franklin
Re: SAFE - Shut down of the GEM
The 5 VDC Power should be disconnected first than the PT.
I would do this especially if logging to the DashBox so you don't end up with any 0V values.Teken wrote:The 5 VDC Power should be disconnected first than the PT.
