I'm running btmon.py reading a ECM-1240. Long time user, and sometimes a wh counter will reset back to zero.
Any ideas?
Wh reset on it's own?
Re: Wh reset on it's own?
Counters on the ECM-1240 are 5 byte counters (for CH1/CH2) and 4-byte counters (for AUX1-5), they roll over every 256^5 and 256^4 respectively.eric512 wrote:I'm running btmon.py reading a ECM-1240. Long time user, and sometimes a wh counter will reset back to zero.
Any ideas?
What format are you using? It might be worth looking into ecmreadext if you're not using that already as it provides watt hour deltas between packets.
Thanks Ben.
Last two counters on AUX reset near 1189589 and 1189246.
Tried ecmreadext in the btmon.cfg, but saw same channels being spit out to Emoncms, which I'm running locally. Is there something on the ECM-1240 to change for ext channels?
Given you're a long time user, it sounds like the unit is having some issues.eric512 wrote:Thanks Ben.
Have you installed F/W 1.035 from our software section? http://www.brultech.com/software.
It stores the counters in new memory locations in case the ECM-1240 is unable to save its counters to its current location.
After more reading, looks like btmon only uses the extended ecm read for DB writes, not sending to Emoncms. I'll have to dig into the code a little more to understand.
Yup, firmware is a 1.031. I'll do an upgrade is see what happens. Might be a while before I report back.
Thanks Ben!
Thanks Ben!
