Ben,
Is there any negative side effects of inserting a resistor to the GEM's (Data & 5 volt) header if the 1 wire network is operating just fine? Would like to know if there is some kind of benefit to a working system?
Parts ordered, Temp still ornery!
Re: Parts ordered, Temp still ornery!
Since I can't get past step 1 I guess I have a problem with the GEM. When the one wire block is completely disconnected (Ground, Data, +5) I do not get any 'FF' values. The ROM codes are zero except for the last two digits (00-00-00-00-00-00-00-01, 00-00-00-00-00-00-00-81, 00-00-00-00-00-00-00-41, etc.).
The power monitoring of the unit is great so unless there are any more thoughts then I will just accept where I am. I was considering another solution like an Ardunio device or review what solutions Teken (he has everything ) has in place to allow more than the eight channels.
I spoke with Paul and he says it sounds like the FET is damaged.paetzold wrote:Since I can't get past step 1 I guess I have a problem with the GEM. When the one wire block is completely disconnected (Ground, Data, +5) I do not get any 'FF' values. The ROM codes are zero except for the last two digits (00-00-00-00-00-00-00-01, 00-00-00-00-00-00-00-81, 00-00-00-00-00-00-00-41, etc.).
You can try unplugging the GEM and measure the resistance between GND and Data. It should be well above like 10k.
In my *Projects Install* thread I detail the use of a Autelis Bridge. Which offers support for up to 32 1 Wire temperature sensors. I purchased and used this hardware because it offered tight integration with my ISY Series Controller which helps manage my Insteon / Z-Wave home automation system.paetzold wrote:Since I can't get past step 1 I guess I have a problem with the GEM. When the one wire block is completely disconnected (Ground, Data, +5) I do not get any 'FF' values. The ROM codes are zero except for the last two digits (00-00-00-00-00-00-00-01, 00-00-00-00-00-00-00-81, 00-00-00-00-00-00-00-41, etc.).
For me knowing something is only part of the equation. It's having the ability to use that data and act upon it in a meaningful way automatically!
Whether it turns on / off HVAC, fans, switches, outlets, appliances etc.
So...Unless you meant 10 instead of 10K (which I am pretty sure you didn't), I guess that answers that...9.9 ohms.ben wrote:I spoke with Paul and he says it sounds like the FET is damaged.paetzold wrote:Since I can't get past step 1 I guess I have a problem with the GEM. When the one wire block is completely disconnected (Ground, Data, +5) I do not get any 'FF' values. The ROM codes are zero except for the last two digits (00-00-00-00-00-00-00-01, 00-00-00-00-00-00-00-81, 00-00-00-00-00-00-00-41, etc.).
Yeah, it looks like the FET is fried.paetzold wrote: So...Unless you meant 10 instead of 10K (which I am pretty sure you didn't), I guess that answers that...9.9 ohms.
The part number is 2N7002P (MOSFET N-CH 60V 0.36A SOT-23) if you want to try to replace it, it's the 3-pin chip below the terminal strip.
