Parts ordered, Temp still ornery!
Ok, I ordered the resistors to make the USB PT adapter.
The temp sensors:
I have done the search and it finds the only one I have attached, and I've saved it to the config as well.
The temp sensors:
- Attachments
- Here is what it brings me. Not sure why.
- TempResults.JPG (11.3 KiB) Viewed 3028 times
- Here is the search page.
- TempSearch.JPG (82.87 KiB) Viewed 3028 times
Re: Parts ordered, Temp still ornery!
Would you happen to have other 1 wire sensors available that aren't in the 10 series?
The highest calling in life is to serve ones country faithfully - Teach others what can be. Do what is right and not what is popular.
Temporarily switch your packet format to HTTP Get, then click the Show Packet button. Check if it shows up as the 1st temperature sensor there.
What COM F/W are you running? I'll check to Paul to see if that's been fixed in a later version.
So sorry to have created another thread on this, not quite for sure how that happened. Feel free to move it back under the other one.
I checked the rest of my temp sensors, sadly, they are all the 10 series. Does that make a difference?
Switched to HTTP GET
GET extension_here?SN=01000126&SC=16744439&V=1268&c1=1033540328432,1094593519325&c2=885120923155,7
66750215295&c3=978390499883,1086604231374&c4=786173734108,554667830600&c5=1887034
36360,731854819742&c6=133011766697,936353635535&c7=268637412261,663374394883&c8=1
58606159258,362854717566&c9=912229667741,260542582716&c10=613487004135,2707353928
56&c11=1024350080662,859059818779&c12=939655950067,329746510156&c13=284762227018,
956217318579&c14=600185605047,549302755279&c15=301119439492,870448860920&c16=7728
24055727,312827964904&c17=555832861272,659782322727&c18=786341236210,909035695515
&c19=654788671854,102161662237&c20=689821586795,118116243358&c21=124243369669,839
652503811&c22=563389606163,372831140595&c23=1097899769074,738747775698&c24=617990
616328,841507089454&c25=867104396990,831022469083&c26=625393456058,682211395677&c
27=848799466979,955478178970&c28=564501774975,863132376462&c29=156209805243,14140
833500&c30=548646696823,513658887465&c31=242577719635,417045187003&c32=9253894794
77,807129435177&PL=10441138,1890863,7730079,7999910&T=nc,5,,,,,,&key=key1_here&Resp=
HTTP/1.1 Host: host_here.com
I'm currently on the following firmware:
COM firmware ver: 4.32
ENG firmware ver: 1.49
RealTime Status: ON
Packet Send Interval: 8
Pri. Packet Format: 4
Sec. Packet Format: 0
RealTime Status: ON
If its possible could you purchase just one 1 wire sensor from another vendor and report back what the results are. Also, would you please offer a photo of the colored wires from the 1 wire sensors.
To date I haven't seen or heard of anyone ever having issues with the 1 wire sensors besides myself. Meaning, I received a huge batch of sensors which were just duds from the seller.
Sure, I'll look into grabbing another one. The one I'm using I've used before, and I've tested 3-4 of them. Currently I'm using bare DS1820s, the one I'm testing with right now is actually just jammed in the 1wire port on the GEM.
What are the color of the wires? Is the standard red (power) black (ground) yellow (data)?
Just bare sensors, no colors.
- Attachments
- Screenshot_20170625-193642.png (256.98 KiB) Viewed 2959 times
Just for clarity the 1 wire chip is plugged in using the flat side as the reference point from left to right.
Pin 1 Ground
Pin 2 Data
Pin 3 Positive (VDC)
Pin 1 Ground
Pin 2 Data
I'll ask Paul to take a look at the GEM firmware. Based on what you've shown, it shouldn't be happening.
