Last visit was: It is currently Sun Feb 25, 2018 12:53 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
Author Message
 Post subject: Re: Adding Brultech Devices to EmonCMS
PostPosted: Mon Mar 13, 2017 4:52 pm
Registered users
Ok, went to Data Post and clicked dashbox/Standalone software. It puts the URL extension mentioned before in, so I removed it. Saved it, went to Packet Send and clicked Show Packet. Below is the packet, still not getting values on EmonCMS. Could it be hanging up on the "apikey=&node=" section?
GET ?apikey=&node=&json={SC:1062,V:0,E1:4474536,P1:0,E2:17335,P2:0,E3:2348,P3:0,E4:1843,P4:0,E5:1744,P5:0,
E6:1099,P6:0,E7:31,P7:0,E8:74895,P8:0,E9:389860,P9:0,E10:748,P10:0,E11:200509,P11:0,
E12:69,P12:0,E13:897,P13:0,E14:1602477,P14:0,E15:7816,P15:0,E16:39249,P16:0,E17:30670,
P17:0,E18:67,P18:0,E19:64935,P19:0,E20:280965,P20:0,E21:9217,P21:0,E22:14,P22:0,
E23:382841,P23:0,E24:24635,P24:0,E25:75735,P25:0,E26:4215,P26:0,E27:355803,P27:0,E28:0,
P28:0,E29:0,P29:0,E30:0,P30:0,E31:6217,P31:0,E32:35872,P32:0,C1:0,T1:nc,T2:x,T3:x,T4:x,
T5:x,T6:x,T7:x,T8:x,X:0} HTTP/1.1 Host: 192.168.143.158
Also, I gave the EmonCMS raspberry PI another reboot. Its not a raspberry pi 3, if that makes any difference.
Top
Offline Profile
PostPosted: Wed Mar 15, 2017 9:33 am
BrulTech Staff
Been awhile since I last looked at this stuff.
Found some instructions on page 1:
Under "Data Post" fill out the following:
- URL Address: RPi IP Address (eg. 192.168.2.222)
- URL Extension: /emoncms/input/post.json
- Token: Read & Write Input API Token
- Node: If using the Device Module in the original Post, use the same Node Name you defined in Device Setup.
- The rest aren't used.
Extension may change based on whether or not you have a sub folder.
_________________
Top
Offline Profile
PostPosted: Thu Mar 16, 2017 6:42 pm
Registered users
I followed the instructions, but I was still not getting any values. I was getting on the Input Page I was getting NULL as my value. It dawned on me, could it be the port. Went to the GEM network utility, and changed the server IP to my raspberry, and the port to 80. Saved and now getting values.
Now just to get my EmonCMS setup to graph!
Top
Offline Profile
PostPosted: Sat Jul 01, 2017 5:47 am
Registered users
Now I have my Pi Hard Drive (but waiting for a case) and I will be trying to get as much real time data as possible out of my ECM-1240
At present I have these two configurations.
btmon.cfg
[source]
device_type = ecm1240
ip_read = true
ip_port = 8000
ip_mode = server
[oem]
oem_out = true
oem_token = 0052da39089c059f5e3a1914c39d1b25
oem_url = http://localhost/emoncms/input/post.json
oem_node = My_Home[source]
oem_upload_period = 30
serial_read = true
serial_port = /dev/ttyUSB0
serial_baud = 19200
[options]
reverse_polarity = true
and
located in /var/www/html/emoncms/settings.php
<?php
//1 #### Mysql database settings
$server = "localhost";
$database = "emoncms";
$username = "root";
$password = "pass_word";
$port = "3306";
// Skip database setup test - set to false once database has been setup.
$dbtest = true;
//2 #### Redis
$redis_enabled = true;
$redis_server = array( 'host' => 'localhost',
'port' => 6379,
'auth' => '',
'prefix' => 'emoncms');
Any thoughts on what are the best changes / corrections for best performance / most accurate figures?
Many thanks.
Top
Offline Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Theme created StylerBB.net & kodeki
