We hooked up the ECM 1240 to do Net Metering on a PV System. It is listed as an eligible meter in California on this website http://www.gosolarcalifornia.org/equipm ... m_perf.php
However, it states that it is not eligible for Performance Based Incentives. Apparently we need to have a certificate documenting accuracy to less than 2%.
Does this certificate exist so that we could use the ECM 1240 to get PB incentives?
Solar Incentives
Re: Solar Incentives
We don't have that certificate. It would have to be tested with specific CTs and PTs.bel wrote:We hooked up the ECM 1240 to do Net Metering on a PV System. It is listed as an eligible meter in California on this website http://www.gosolarcalifornia.org/equipm ... m_perf.php
We probably won't be pursuing this with the ECM-1240, but might consider it for the GEM in the future.
Hi Ben,ben wrote:We don't have that certificate. It would have to be tested with specific CTs and PTs.bel wrote:We hooked up the ECM 1240 to do Net Metering on a PV System. It is listed as an eligible meter in California on this website http://www.gosolarcalifornia.org/equipm ... m_perf.php
I'm curious if you've tested the GEM for the above purpose or if you still have plans to.
Haven't tested for the above purpose yet. Probably won't get to do anything along those lines for awhile due to the need for better documentation, etc.bel wrote:Hi Ben,
