Having recently purchased the Brultech Mono kit 1240 with 10 x 40amp CT's 2 x 80 CT's and the 2 x 100amp split, I am having very little success in obtaining meaningful readings from the Aux channels. I have installed the CT's and have CH1 and Ch2 giving believable results, but the aux channels all give random and considerably higher results than either possible or believable. I am relatively IT literate and understand electronics to a reasonable level, but so far have not resolved this problem. Any ideas?
Seems like data is corrupted, but have tried 2 other PC's using direct serial along with USB to serial convertors, so this is unlikely to be the problem.
Problem with Aux channels and spurious readings
Re: Problem with Aux channels and spurious readings
What CTs do you have connected to each channel?machjobe wrote:Having recently purchased the Brultech Mono kit 1240 with 10 x 40amp CT's 2 x 80 CT's and the 2 x 100amp split, I am having very little success in obtaining meaningful readings from the Aux channels. I have installed the CT's and have CH1 and Ch2 giving believable results, but the aux channels all give random and considerably higher results than either possible or believable. I am relatively IT literate and understand electronics to a reasonable level, but so far have not resolved this problem. Any ideas?
