equipment installation location
msturtz
Post by msturtz » Wed Jun 08, 2011 6:17 pm
Is there any particular reason the ECM can't be installed inside the panel? Is it just a certification issue?
I already have 3 meters and 2 knive disconnect switches on the outside of my house, besides the main breaker panel -- and that doesn't count the phone and cable boxes. Having another enclosure doesn't thrill me. :-)
Re: equipment installation location
Post by ben » Thu Jun 09, 2011 10:55 am
We don't advise installing it in the panel, it'd be at your own risk.
The problem is mostly safety issues; for example, to prevent line power from touching the communication line.
Would it be possible to mount it inside then run the CT leads through the wall?
msturtz
Post by msturtz » Thu Jun 09, 2011 11:22 am
Well, I'd have to run a conduit down from the panel to below the floor, and then into the basement -- 3+ feet...
I don't think I care too much about running an RS232 cable into the panel -- could even make it 5 wires, and run power and data.
How about environmental factors, will the Colorado cold affect the unit?
Post by ben » Thu Jun 09, 2011 11:27 am
msturtz wrote:Well, I'd have to run a conduit down from the panel to below the floor, and then into the basement -- 3+ feet...
As long as it stays above 0, it's OK.
msturtz
Post by msturtz » Thu Jun 09, 2011 11:56 am
ben wrote:As long as it stays above 0, it's OK.
Yeah, that might be a problem, it certainly gets colder than that here... Is it a certification thing, or is there something bad that'll happen to the unit? Is there an oscilator that slows down in the cold, making it less accurate?
Post by ben » Thu Jun 09, 2011 11:58 am
It'll just affect the accuracy, due to the voltage reference.
