Hi,
I would like to purchase a package for my home which I am in the early stages of building. I've selected the package I believe I will need given my desired number of channels and reporting setup, but when my builder talked to our electrical sub-contractor (Southern State) he said he was unfamiliar with the Brultech system and suggested finding a qualified installer (lame...). I would learn how to do it myself, but I'm fairly disabled with a spinal cord injury (very little hand function and upper body movement)
Can anyone recommend an electrician in the norther virginia (loudoun county) area that might be willing to help me?
Rob
Help with install.
Re: Help with install.
Hey Rob,flxc4p4str wrote:Hi,
Rob
Send me an email at ben(at)brultech.com, and I can send you an installation manual you can show so they get a better feel about it.
Installation shouldn't be too difficult for any electrician. For Micro-CTs, you loosen the screw on the breaker, take the wire out, slide the CT over, and screw it back in. For Split-CTs, you just need to clamp it around the wire.
IMHO, ANY electrician can install this easily, especially during new construction. But, you probably want to calm the electrician down by stating that you only need the CTs physically installed in the breaker panel and the CT wires run to a designated spot (near the breaker panel, where you will mount your ECM-1240). Then state that you (or an assistant/friend) will be responsible for the actual installation and configuration of the ECM-1240.
~Wayne in Florida
