GEM + Grafana + Home Assistant
I have Grafana setup and have data being ingested. I wanted to add Home Assistant as well. I am struggling with how to get the data in to both Grafana and Home Assistant. I know, I could hook up both serial ports on each GEM, but was hoping there might be a way without going that route.
Re: GEM + Grafana + Home Assistant
How are you sending to your computer? Should be able to multiplex it somehow via software (listen via Python and send to both programs).heimdm wrote: ↑Sat Nov 27, 2021 8:38 pmI have Grafana setup and have data being ingested. I wanted to add Home Assistant as well. I am struggling with how to get the data in to both Grafana and Home Assistant. I know, I could hook up both serial ports on each GEM, but was hoping there might be a way without going that route.
The home assistant plugin uses TCP Server mode on the GEM. The plugin simply requires you to put in the port. On the Grafana side it just needs to get into the database via btmon.py in either TCP client or server mode.
1) Can btmon.py be configured to act as TCP client and send traffic to Home Assistant that is acting as TCP client?
2) Can the gem be configured to send traffic to multiple network destinations?
Right now, while I wait for my ethernet modules to arrive, I have COM1 (gem) connected to an IP2SL global cache box, and then running VSPE (Virtual Serial Port Emmulator) to connect to the IP2SL (globalcache) and send it to an IP destination. I haven't found a way to multiplex that traffic and send it to multiple destinations.
After my last reply I tried a few different things with VSPE... and seem to have got the multiplex thing to work.
1. Create a Connector to COM1 (local PC)
2. Create a TCPClient to the global cache IP2SL (TCP 1 => <globalcache-ip>:4999
3. Create a Splitter Device to virtualize COM1 and expose it as COM10 (COM1 => COM10)
4. Create a bridge between COM10 and Home Assistant (Serial Port <=> TCP Client)
5. Create a bridge between COM10 and Grafana (Serial Port <=> TCP Client).
This does appear to work, the only challenge would be having to build a windows VM to run this port replication configuration and making sure it is always running. If you could somehow set multiple server destinations in the GEM network configuration, that would probably be ideal, but I am guessing that probably isn't trival to do within the GEM firmware.
1) BTMon.py is only setup to ingest packets and convert to different formats.heimdm wrote: ↑Mon Nov 29, 2021 1:27 pmThe home assistant plugin uses TCP Server mode on the GEM. The plugin simply requires you to put in the port. On the Grafana side it just needs to get into the database via btmon.py in either TCP client or server mode.
2) The GEM can only send to one client at a time.
What I would do is take something like this: https://github.com/pricheal/python-clie ... /server.py
- Modify run so it just runs forever with each client (I think below should work)
def run(self):
while self.signal:
try:
data = self.socket.recv(32)
if data != "":
print("ID " + str(self.id) + ": " + str(data.decode("utf-8")))
for client in connections:
if client.id != self.id:
client.socket.sendall(data)
except socket.error:
pass
time.sleep(0.2)
- Setup BTMon.py and HA to connect to it.
- Setup the GEM to connect to it.
It should push the GEM packet to both BTMon.py and HA.
Your response came in before I posted this, what are you running HA and BTMon.py on?
I am running it as linux VM's mostly, HA is running virtually as well.
Now that my ethernet modules have arrived I am circle back on this.
1) Within the GEM network setting, I configured the GEM to act as TCP Server and send data to Home Assistant on port 8000. Home Assistant then gets all the data from the various GEMs in one spot.
2) Within the btmon3.py script instances, I have them running as a service/daemon, it is running in TCP client mode, and dumps the data into my sql database.
This easily gets the data into both Home Assistant and Grafana. In the end, the data is mostly in the home assistant database, so you could configure grafana to search the home assistant database. However, it is a lot easier to work with the database that btmon creates over home assistant, mostly because with btmon all the data is in a single record for the given time stamp.
I have the dashbox, but another option that works would be to setup the GEM in Home Assistant, and then configure InfluxDB and pipe GEM data from Home Assistant to InfluxDB. From there you can easily pull into Grafana and it has the added benefit of not crushing your HASS DB. This is what I am doing and it works really well.
I am utterly confused by the home assistant integration (i see there are 17 of us using it though!)
I have never managed to get the GEM to send data to home assistant.
I configured the tab in GEM but nothing is ever seen by hass.
Can i get dashobx to send instead?
I seem to have answered my own question, this works.scyto wrote: ↑Tue Dec 14, 2021 2:45 pmI am utterly confused by the home assistant integration (i see there are 17 of us using it though!)
- Screenshot 2021-12-14 115032.png (47.86 KiB) Viewed 5958 times
