Weather Flo and solar production
seacontracting
Post by seacontracting » Wed Feb 06, 2019 5:24 am
Hi There
I read that the feather flow also records solar radiation which I hope is the same as solar irradiance in W/m2
Does this also get logged by the dashbox ?
If it is logged, I guess it would be possible to create power graphs which can compare solar production with solar radiation ?
Has anyone done this ?
Re: Weather Flo and solar production
Post by ben » Wed Feb 06, 2019 10:08 am
seacontracting wrote:Hi There
We currently only support Humidity, Pressure, and Temperature (WeatherFlow Air). The Sky isn't supported yet. I'm out of the office today due to an ice storm, but I can check tomorrow to see how far along the Sky integration was.
seacontracting
Post by seacontracting » Wed Feb 06, 2019 5:28 pm
Awesome
Thanks Ben
Kilo_SSK
Post by Kilo_SSK » Thu Feb 28, 2019 11:56 am
For which temperatures is the Weather flow calibrated? Because I was planning to buy this house in Thessaloniki, Greece and move there now that I can work from home, but as you can see, it's in a very sunny place and the roof is quite large, I'm afraid it'll create a large zone that's hotter than usual and mess with the input.
If it is a problem, I'll try to put the readers further away from the house in the yard and put solar panels on the roof instead.
GaryFunk
Post by GaryFunk » Thu Feb 28, 2019 9:40 pm
I read that WestherFlow also records solar radiation which I hope is the same as solar irradiance in W/m2
it actually calculates the solar radiation based on illuminance. It's approximately 0.008403 x of illuminance.
GaryFunk
Post by GaryFunk » Thu Feb 28, 2019 9:43 pm
Kilo_SSK wrote:For which temperatures is the WeatherFlow calibrated?
I don't understand what you are asking.
However The unit that measures temperature sits in a shaded area and will not be affected by the heat from the roof.
Kilo_SSK
Post by Kilo_SSK » Sat Mar 02, 2019 3:38 am
Okay, thanks for the answer! I was wondering whether the temperature there would be too much, and if the roof or something else could create interferences, turns out I don't have to worry about it!
seacontracting
Post by seacontracting » Tue May 14, 2019 5:45 pm
Hi Ben
can i please get an update on this
Post by ben » Wed May 15, 2019 9:59 am
seacontracting wrote:Hi Ben
Haven't had a chance yet, too much on the go right now.
seacontracting
Post by seacontracting » Fri May 17, 2019 8:06 pm
all good
