Weather Flow Information?
I have the OpenWeatherMap information configured to pull using the API key, but I'm not seeing any graphing, plotting, ect.
Any ideas what I'm missing. I know it's not a lot of information to go on but I'm not sure what I don't have set.
Re: Weather Flow Information?
When you press the *Test API* does it return with any valid weather metrics? Also on the loads / channels tab is the LED green or grey? Have you tried to reboot the DB both using soft boot and hard boot?Visseroth wrote:I have the OpenWeatherMap information configured to pull using the API key, but I'm not seeing any graphing, plotting, ect.
Lastly, in Google Chrome web browser sometimes there is a cache issue so you may have to select F12. Once the developers window opens you can hover your mouse over the refresh button and right mouse click and select force *Empty Cache & Hard Reload*.
Please let us know what each check results in . . .
Yep, it does indeed give me output...
OK, so this thing I trying to make me look stupid! LOL
I did the firmware update last night, was playing with it, couldn't get it to work but now I'm seeing the channel, last night, I swear it wasn't there. I looked for it!
It started graphing last night at about 1:30am, which about after I stopped playing with it!
So is there any way to overlay the weather on the Summary screen's graph?
Is there also a way to default the Summary graph to Wattage usage instead of the default KWh?
And lastly, I've been seriously considering getting a weather station for personal and public use (Online weather station). Any recommendations on one that'll work with this system and work as a public weather station?
The Brultech team has began supporting the Weather Flow system: http://weatherflow.com/Visseroth wrote:Yep, it does indeed give me output...
OK. I opened a tab and will look into it more.
Anything on the summary page graphing for weather and wattage?
You'll have to use the channels section to graph weather versus wattage.Visseroth wrote:OK. I opened a tab and will look into it more.
The version we're working on supports weather and pulse across all the Overview pages.
Yea, saw the graph on the channels. And good to know you're working on the graphing overlay on the summary page.
Thanks for the update. I'll wait for the next update
