How to Shutdown / Poweroff Dashbox
Is there a proper / recommended way to power-down the Dashbox before unplugging the power supply? I see an option to "Reboot System" in the system menu but no shutdown.
Re: How to Shutdown / Poweroff Dashbox
Just unplug it, it goes through a shutdown sequence once it detects power loss.cvachon79 wrote:Is there a proper / recommended way to power-down the Dashbox before unplugging the power supply? I see an option to "Reboot System" in the system menu but no shutdown.
Thank you - I was not sure if pulling the power could corrupt the file system. Good to know if performs a shutdown sequence.
ben wrote:Just unplug it, it goes through a shutdown sequence once it detects power loss.cvachon79 wrote:Is there a proper / recommended way to power-down the Dashbox before unplugging the power supply? I see an option to "Reboot System" in the system menu but no shutdown.
