mgandalf
Post
by mgandalf » Mon Jul 24, 2017 6:17 pm
ben wrote:Yeah, I sent it to that address. It had 2 files attached so it might take some time to go through. If it doesn't reach you in an hour or so let me know and I'll resend. The email might've hit some sort of filter as the zip contains an executable.
It hasn't arrived, so I'm guessing Google is silently blocking the email because of the .exe. Can you zip or rename the file? I apologize for all the hassle.
- Mark.
Post
by ben » Tue Jul 25, 2017 9:32 am
mgandalf wrote:ben wrote:Yeah, I sent it to that address. It had 2 files attached so it might take some time to go through. If it doesn't reach you in an hour or so let me know and I'll resend. The email might've hit some sort of filter as the zip contains an executable.
- Mark.
Not a problem, I'll PM you the links and send you a basic email to confirm the .exe issue.
cjin
Post
by cjin » Sun Nov 17, 2019 1:39 am
ben wrote:mgandalf wrote:Good morning. Recently this has happened to me. I had a power outage and when the unit came back online I had to reconfigure it. The serial number was zero'ed out and the unit number went from unit 1 to unit 0.
Is there a battery in the unit which may need replacing after a time? My unit is probably 4 years old as well.
- Mark.
There's no battery in the unit.
Emailed you over a new F/W and sent over an IA version to reprogram the S/N. That should fix up your issue.
I know this is an old threat... same thing just happened to my 1240 as well. After a power cycle its serial number got set to 0-00000 (read with IA utility). How can I reset it?
Thank you.
Post
by ben » Mon Nov 18, 2019 10:52 am
Thank you.
Yeah, will do. You should get it in the next 5-10 minutes.
cjin
Post
by cjin » Mon Nov 18, 2019 11:27 am
Hi Ben, the attachment didn’t come through. Maybe gmail is blocking .exe files. Could you please try zip it before sending?
Thank you very much for your assistance.
Post
by ben » Mon Nov 18, 2019 11:37 am
cjin wrote:Hi Ben, the attachment didn’t come through. Maybe gmail is blocking .exe files. Could you please try zip it before sending?
PM'd you links to them as GMail rejected it.
cjin
Post
by cjin » Mon Nov 18, 2019 12:35 pm
ben wrote:cjin wrote:Hi Ben, the attachment didn’t come through. Maybe gmail is blocking .exe files. Could you please try zip it before sending?
Thank you. Downloaded it and connected to ECM-1240, how do I set the serial number?
cjin
Post
by cjin » Mon Nov 18, 2019 12:39 pm
cjin wrote:ben wrote:cjin wrote:Hi Ben, the attachment didn’t come through. Maybe gmail is blocking .exe files. Could you please try zip it before sending?
Never mind, found it on firmware update tab.
About firmware update, I have an old unit with both F1 and F2 switch. Instruction says press both F1 F2 while powering up, then release F1. Do I need to keep F2 pressed all the time? Will this erase calibrations?
Post
by ben » Mon Nov 18, 2019 12:58 pm
cjin wrote:About firmware update, I have an old unit with both F1 and F2 switch. Instruction says press both F1 F2 while powering up, then release F1. Do I need to keep F2 pressed all the time? Will this erase calibrations?
What F/W version is on there? If the S/N reset fine, maybe just run it as-is for now. I'll have to get Paul to look at compatibility with those old units and new F/W.
cjin
Post
by cjin » Mon Nov 18, 2019 1:40 pm
ben wrote:cjin wrote:About firmware update, I have an old unit with both F1 and F2 switch. Instruction says press both F1 F2 while powering up, then release F1. Do I need to keep F2 pressed all the time? Will this erase calibrations?
It is ruing 1.031, after reset serial number it seems to be running fine. Thanks again for your help!
