Extension of the STS cable
Can the STS Cable which came with the DashBox be extended by using a stereo 3.5mm headphone extension cable? Is there a max distance? I need 25 feet.
Re: Extension of the STS cable
I can't think of any issues you'll have doing that.dbksearay wrote:Can the STS Cable which came with the DashBox be extended by using a stereo 3.5mm headphone extension cable? Is there a max distance? I need 25 feet.
I have used CAT5 cable to bridge about 35 ft between Dashbox and GEM. On very rare occasions I do lose connection. The most recent firmware has dramatically improved on that and since updating I have not received any more dropped package notes. So you should be fine
