Can you send a link so I can read about the pulse gas meter accessory? When reading about the Dashboard I saw mention of being able to monitor; electricity, water and gas. I want to see if your pulse meter is compatible with my utilities gas meter.
Thank you
Monitoring Gas
Re: Monitoring Gas
We don't have an accessory for gas (adding a pulse meter to gas gets complicated due to regulations), the utility meter has to have an pulse output for it. The pulse count section on http://www.brultech.com/greeneye/ has information on the pulse inputs.LLB wrote:Can you send a link so I can read about the pulse gas meter accessory? When reading about the Dashboard I saw mention of being able to monitor; electricity, water and gas. I want to see if your pulse meter is compatible with my utilities gas meter.
Thank you
