Hi,
i cand find the wiring & electrical specs of the Micro-40 Current Transformer.
are they available?
the CT comes with a 2mtr cable, is there a jack plug connected at the end?
I can't find detailed datasheets on the brultech site, so I don't know if you have a burden resistor built in or not.
Also, it is unclear if you have over voltage protection?
Is there a need to use a burden resistor for the 40A type when i want to use it with a arduino board?
If so, how much Ohms does it need to be?
Micro-40 CT: wiring & electrical specs
Re: Micro-40 CT: wiring & electrical specs
hemertje wrote:Hi,
are they available?
- Specs for the Micro 40 are listed here: http://www.brultech.com/home/store/cate ... ategory=18
- The CT wire is simply tinned with solder no PJ at the end.
- Brultech will need to reply back if the Micro 40 has a burden resistor with in it. I do know the GEM has the burden resistor incorporated into its PCB.
- Brultech will need to reply back what value is required for the Arduino.
