Showing usage when breaker off
Okie69
Post by Okie69 » Wed Jul 22, 2015 7:36 pm
I have one channel/breaker that shows 3 to 4 watts usage. It is a double pole that I think goes to the central air heat element. I have turned it off and even pulled the breaker, but doesn't stop usage. I also turned off the other two breakers that feed the central heat/air unit. Didn't make any difference. Any thoughts?
Re: Showing usage when breaker off
Post by Teken » Thu Jul 23, 2015 12:17 am
Okie69 wrote:I have one channel/breaker that shows 3 to 4 watts usage. It is a double pole that I think goes to the central air heat element. I have turned it off and even pulled the breaker, but doesn't stop usage. I also turned off the other two breakers that feed the central heat/air unit. Didn't make any difference. Any thoughts?
More than likely its noise on the line which can be solved by placing a piece of thin insulated wire in channels 1 & 2 of that PJ.
Okie69
Post by Okie69 » Thu Jul 23, 2015 4:46 pm
Ok help me a little further. Not sure what PJ is. Do you mean putting wire in where the CT connects to the GEM? if so I'm using 2&3 so what do I do?
Post by Teken » Thu Jul 23, 2015 5:05 pm
Okie69 wrote:Ok help me a little further. Not sure what PJ is. Do you mean putting wire in where the CT connects to the GEM? if so I'm using 2&3 so what do I do?
A PJ is the Plug Jack and you will simply insert a insulated piece of wire into channels 1 & 2.
At the bottom of my signature is my install thread. Click on page 5 and almost near the bottom is a picture and a trouble shooting FAQ.
