ECM-1240 for europe install?
psykok
Post by psykok » Mon Jun 08, 2015 9:09 am
Hi,
I have discovered the ecm-1240 after I searched for a solution to monitor my installation.
I found that the ecm-1240 was compatible with 50HZ installations using a special firmware.
Did some one know if it's still possible to order a 50Hz version ?
Regards,
Alex
Re: ECM-1240 for europe install?
Post by ben » Mon Jun 08, 2015 9:39 am
We no longer carry 50Hz ECM-1240s. Our GEM however is 50Hz compatible.
psykok
Post by psykok » Mon Jun 08, 2015 10:13 am
Hi,
Thanks for the info.
How many lines can we monitor with the GEM in a 50Hz 240V single phase system?
Alex
Post by ben » Mon Jun 08, 2015 11:10 am
psykok wrote:Hi,
Alex
The GEM has 32-channels (more information here http://www.mypowerpanel.com/greeneye/). So up to 32 breakers individually, or more if you don't mind combining some breakers onto one channel.
