I have wondered if there was a difference in accuracy for the CT40 vs. the CT80 on a lower amperage circuit, even down to 15 amps. If for some reason a CT80 was used there on a 15 amp circuit, is it then less accurate than a CT40 used there?
The specs give the 3% accuracy, but don't really say for what range of current.
This is more a theoretical question than a need to know question.
Also, without cluttering up the topics, I was wondering approximately how much accuracy would be lost just using 1 CT on a 240V circuit and doubling the amount, instead of the two CTs as is proper. Have people seen an imbalance between the two separate legs?
Thanks for the help.
CT Accuracy / CT40 vs. CT80 for 15 amp circuit
Re: CT Accuracy / CT40 vs. CT80 for 15 amp circuit
There's an accuracy chart for each CT here under specs:sub3marathonman wrote:I have wondered if there was a difference in accuracy for the CT40 vs. the CT80 on a lower amperage circuit, even down to 15 amps. If for some reason a CT80 was used there on a 15 amp circuit, is it then less accurate than a CT40 used there?
http://brultech.com/products/ECM1240/pa ... icro40.htm
http://brultech.com/products/ECM1240/pa ... icro80.htm
1A or less, or the upper scale of each CT is when things tend to get inaccurate.
If it's a balanced load, there shouldn't be any accuracy loss. If it's something like a dryer, etc. you need to use 2 CTs.sub3marathonman wrote:Also, without cluttering up the topics, I was wondering approximately how much accuracy would be lost just using 1 CT on a 240V circuit and doubling the amount, instead of the two CTs as is proper. Have people seen an imbalance between the two separate legs?
That's exactly what I was looking for. I don't know why I didn't see it myself.ben wrote:
Thank you for the help.
