depasseg
Post
by depasseg » Tue May 20, 2014 8:16 am
Teken wrote:Would it not be better served to have a solution in place which not only protects the system but also allows the system to continue to operate in such an event?
Worth the protection, Yes.
Worth the loss of 60 seconds of data, No.
I'm not sure of the OP's situation, but mine does not lend to an easy install of a UPS due to the location of the panel, GEM, and DB. Do you know of an extremely small wall mountable UPS.
Post
by Teken » Tue May 20, 2014 8:22 am
depasseg wrote:Teken wrote:Would it not be better served to have a solution in place which not only protects the system but also allows the system to continue to operate in such an event?
Hello Greg,
How small does it have to be? Let me see what I can find that might meet your needs.
depasseg
Post
by depasseg » Tue May 20, 2014 8:29 am
Around the size of the GEM would work.
tnakelski
Post
by tnakelski » Tue May 20, 2014 10:22 am
depasseg wrote:Around the size of the GEM would work.
I actually used a Functional Devices model PSH2C2RB10 unit, which you can install a UPS in it. This setup allows you to run separate outlets to different devices that you want on a couple of UPS protected circuits. This does require some wiring / rewiring. In my case everything is located in the basement so I just ran some additional outlets to a couple of different places. I have my GEM, Dashbox, ISY-99i and my internet router on it along with a couple of other small things. Functional Devices has a couple of different models and configurations. I have also included a PDF which shows how it get wired up,
- psh2c2rb10.jpg (14.41 KiB) Viewed 1908 times
- PSH2C2RB10.pdf
- wiring
- (402.84 KiB) Downloaded 153 times
scyto
Post
by scyto » Tue May 20, 2014 1:26 pm
Ooh, I like that box. I have power supplies to hide for the GEM, the Dashbox, a POE switch, and a DSC alarm system I have put in.
Do you have a recommended place on the web where I can go see a variety of these boxes, look at their depths etc?
Alex
tnakelski
Post
by tnakelski » Tue May 20, 2014 1:52 pm
scyto wrote:Ooh, I like that box. I have power supplies to hide for the GEM, the Dashbox, a POE switch, and a DSC alarm system I have put in.
Alex
Here is the manufactures web site, they a little pricy
http://www.functionaldevices.com/building-automation
tnakelski
Post
by tnakelski » Tue May 20, 2014 2:04 pm
tnakelski wrote:scyto wrote:Ooh, I like that box. I have power supplies to hide for the GEM, the Dashbox, a POE switch, and a DSC alarm system I have put in.
Alex
The first photo shows the box which contains the UPS (red Circle), the second photo shows the UPS outlets (orange Circles)
- 2014-02-26_22.33.21.jpg (209.11 KiB) Viewed 1902 times
- 2014-02-26_22.31.40.jpg (215.92 KiB) Viewed 1902 times
depasseg
Post
by depasseg » Tue May 20, 2014 3:16 pm
Where did you buy that box?
tnakelski
Post
by tnakelski » Tue May 20, 2014 5:12 pm
depasseg wrote:Where did you buy that box?
Picked it up on e-bay last year.
