Do I use 1 or 2 CTs on a 120v GFCI breaker?
I have 2 breakers that are GFCI breakers. They have 2 wires, including a white. I assume this is a neutral? Should I use 1 or 2 CTs and if 1 which wire does it go on?
Re: Do I use 1 or 2 CTs on a 120v GFCI breaker?
One Ct on the (hot/load/black) wire, not the white/neutral wire.scyto wrote:I have 2 breakers that are GFCI breakers. They have 2 wires, including a white. I assume this is a neutral? Should I use 1 or 2 CTs and if 1 which wire does it go on?
