I have an induction cooktop (2-phase 50A breaker) and a wall oven (2-phase 30A breaker) that I'd like to monitor together on CH2. I'm wondering what the best/simplest setup would be.
I already have two micro-80s, and hoped I could thread both Phase A's through one, and both Phase Bs through the other, but that 50A wire is too thick.
So I could get 2 more micro-80s and connect all four to CH2, but another thread here made it look like that was a somewhat complex setup.
Alternately, I could get two micro-100s, and thread both Phase As through one and both Phase Bs through the other. Would that be simplest?
Or - couldn't I put one micro-80 on each Phase A of each appliance, and just double the values? I suppose that'd take something in the firmware, but for a resistive appliance like the oven, shouldn't that work?
Also, regardless of which micro-XX I choose - they are supposed to be connected in parallel to CH1/CH2, across DUAL and COM, with the burden resistor, correct?
-Eric
Best plan to connect oven & cooktop to CH2?
Re: Best plan to connect oven & cooktop to CH2?
The induction cooktop may not have a neutral, but the wall oven likely does (due to the oven fan). So, to combine them both onto one channel, you'll need a CT on each leg. If they both didn't have neutrals, you can monitor them both with a single CT on one leg.sandeen wrote:I have an induction cooktop (2-phase 50A breaker) and a wall oven (2-phase 30A breaker) that I'd like to monitor together on CH2. I'm wondering what the best/simplest setup would be.
-Eric
You're best off using a separate CT on each leg. Running multiple wires through one CT is the least desired setup in our opinion due to having to get phasing right, etc.
Micro-80s/40s basically have the same CT settings, so you can pick up a pair of Micro-40s for the 30A breakers. You could actually run all 40s if you wanted to in most situations as by electrical code, a breaker must not exceed 80% of its rating. If it went over for any reason, the reading would just get capped at 40A.
Thanks Ben - would you have the same advice if I want/need to use CH2 for this? All the Aux channels are full... that's why I was thinking it might be simplest to thread both phase A's through one CT and both phase B's through the other...
I was underthe impression that it wasn't a trivial thing to add more than 2 CTs to the CH1/CH2 channels.
It's basically trivial, I would grab 4 Micro-80s and include in your order notes that you need a 4.99 ohm resistor.sandeen wrote:Thanks Ben - would you have the same advice if I want/need to use CH2 for this? All the Aux channels are full... that's why I was thinking it might be simplest to thread both phase A's through one CT and both phase B's through the other...
Then you just connect the resistor in line with the CTs, all in parallel (phase B CTs reversed).
Ok, thanks! I had seen some other post with a more complicated schematic for 4 CTs on CH1/CH2, but maybe that was for non-micro CTs.
Thanks for the info, Ben.
-Eric
-Eric
