CT Orientation For GEM
I'm getting ready to do my GEM install finally, and was reading through the manual and was a little confused on the CT orientation topic and had a couple of questions:
1. Split-200 CT's - On a 200A panel, which direction does the arrow go? Arrow inwards/downwards towards the rest of the breakers or outwards/upwards towards the panel frame?
2. Micro-50 CT's - Has a "dot" on the "shiny" side, does the dot/shiny side face the breaker or away from the breaker?
3. Micro-80 CT's - No arrow or "dot" but looks the same as the Micro-50 has a "flat" and "shiny" side, does the "shiny" side face the breaker or away from the breaker?
Also I read something saying that for 240V load, on one cable/circuit/black wire the arrow/dot/shiny side faces the breaker, and the other cable/circuit/red wire the arrow/dot/shiny side faces away from the breaker towards the panel frame. Is this correct?
I know technically it does not matter which direction the "arrow/dot/shiny side" faces since you can just swap the wire connections around at the GEM, but I would prefer to setup everything the correct way the first time around so everything is the same.
Also I have 4 Split-200 CT's that I will be connecting to the 2 panels feeding my house, Can I connect all 4 Split-200's to CH1 (Panel #1 CT #1 and Panel #2 CT #1 goes to pin 1-2 on CH1 and Panel #1 CT #2 and Panel #2 CT #2 goes to pin 3-4 on CH1) or must I split them across CH1 and CH2?
GEM + WiFi & Ethernet Module / DashBox + TL-WN722N
4 x Split-200 CT's / 60 x Micro-50 CT's / 8 x Micro-80 CT's
Current 2014-03-31: GEM COM v2.58 / GEM ENG v1.47 / DB Dashboard v4.1.5F1
Previous: GEM COM v2.57 / GEM ENG v1.47 / DB Dashboard v4.1.5B
Re: CT Orientation For GEM
Opposing eachother, one pointing up and one pointing down.OzTechGeek wrote:I'm getting ready to do my GEM install finally, and was reading through the manual and was a little confused on the CT orientation topic and had a couple of questions:
Only really need to worry about orientation when installing 2 CTs onto one channel. 240V circuit CTs must face opposite directions, 120V CTs must face the same direction. It's so they don't cancel from each other.OzTechGeek wrote: 2. Micro-50 CT's - Has a "dot" on the "shiny" side, does the dot/shiny side face the breaker or away from the breaker?
You'll have to put them in series, so for example:OzTechGeek wrote:Also I have 4 Split-200 CT's that I will be connecting to the 2 panels feeding my house, Can I connect all 4 Split-200's to CH1 (Panel #1 CT #1 and Panel #2 CT #1 goes to pin 1-2 on CH1 and Panel #1 CT #2 and Panel #2 CT #2 goes to pin 3-4 on CH1) or must I split them across CH1 and CH2
CT1 lead 1 into Port 1, CT1 lead 2 and CT2 lead 1 twisted together, CT2 lead 2 into Port 2.
CT3 lead 1 into Port 3, CT3 lead 2 and CT4 lead 1 twisted together, CT4 lead 2 into Port 4.
(hard to put into words)
Ben,
Why doesn't it say to have the split 200 CTs in opposite directions anywhere that I could find? Have you thought about doing a quick start, I have to say I found the installation of just the 2 x 200 Split CTs and setting up the software VERY confusing.
Alex
Alex
Hello Alex,scyto wrote:Ben,
Alex
The Split 200 amp CT is marked with an arrow which identifies the correct orientation of the CT. Even if you made a mistake in orientation all you need to do is reverse the wires at the end.
But that's the point they have two go in opposite directions when being used on a single channel. Your install pictures threw me because you had them in the same direction. I think it's because you put each one on a different channel.
My point was is there is so much info I struggled to comprehend it all. I think they need a better QuickStart guide. But that comes after the new web site
You're absolutely correct! I don't believe there are too many people installing their primary CT's on two separate channels like I have.scyto wrote:But that's the point they have two go in opposite directions when being used on a single channel. Your install pictures threw me because you had them in the same direction. I think it's because you put each one on a different channel.
I did this to ensure I was able to see the generated power, along with having a more granular view of which side of the home was using more power etc.
My apologies for the confusing!
Oh it was very sensible what you did. I already have an issue of 32 channels vs ~38 breakers so had to do some combining I guess I need ben to develop that expansion !
Hello Alex,scyto wrote:Oh it was very sensible what you did. I already have an issue of 32 channels vs ~38 breakers so had to do some combining I guess I need ben to develop that expansion !
If you have not added your voice to this thread please do!
http://www.brultech.com/home/community/ ... f=29&t=967
