Main Channel - Watts
cdnjeepin
Post by cdnjeepin » Mon Feb 10, 2014 2:26 pm
So i am thinking that if I am monitoring all breakers on my fuse panel, the total watts of the main channel should be equal to all the other channels combined.
I know it wont be 100% due to different times packets are set, but it should be close i would think.
right now my SAD says 1411watts
if i add them up, i have 924watts
Re: Main Channel - Watts
Post by Teken » Mon Feb 10, 2014 2:54 pm
What is a SAD? :?:
cdnjeepin
Post by cdnjeepin » Mon Feb 10, 2014 2:57 pm
stand alone dashboard..i think
its the brlutech dashboard..
Post by ben » Mon Feb 10, 2014 4:22 pm
cdnjeepin wrote:So i am thinking that if I am monitoring all breakers on my fuse panel, the total watts of the main channel should be equal to all the other channels combined.
What monitors are you using?
cdnjeepin
Post by cdnjeepin » Mon Feb 10, 2014 6:30 pm
Figured out the problem. My electric heater cts must be set wrong. Only reading 120v instead of 240v
Post by ben » Tue Feb 11, 2014 11:32 am
cdnjeepin wrote:Figured out the problem. My electric heater cts must be set wrong. Only reading 120v instead of 240v
If you're monitoring with one CT (assuming it has no neutral),
- In terms of the AUX channels on the ECM-1240, you'll have to enable X2 settings.
- CH1/CH2 or any channel on the GEM, dropping the range by 1 will double the value. The GEM has a toggle for this under the CT settings section.
