Reset Running Values
Posted: Fri Oct 27, 2023 3:51 pm
by jkosharek
I have 2 Gems feeding in to dashbox and dashbox feeding out to NodeLink which allows my energy data to be brought in to the ISY/IoX platform.
I am trying to figure out how to reset the counters that I have my water meters connected to, as well as the Total Energy and runtime of the power channels.
Re: Reset Running Values
Posted: Mon Oct 30, 2023 10:38 am
jkosharek wrote: ↑Fri Oct 27, 2023 3:51 pm
In the GEM Setup Webpage under Adv you can reset the counters there.
There's also some commands that could be sent:
^^^SYSRSTA (all counters)
^^^SYSRSTP (pulse counters)
https://brultech.com/software/files/dow ... _11.0_.pdf)
Posted: Wed Nov 15, 2023 5:29 pm
by jkosharek
ben wrote: ↑Mon Oct 30, 2023 10:38 am
What do I use to send the commands to the Gems?
Posted: Thu Nov 16, 2023 10:35 am
jkosharek wrote: ↑Wed Nov 15, 2023 5:29 pm
Any TCP connection. You could use the GEM Network Utility.
It's likely easiest just to bring up the GEM Setup Webpage and go under Adv however.
Posted: Thu Nov 16, 2023 11:11 am
by jkosharek
Would I telnet/connect to port 8000 and run the command, My thought is reset it on a monthly basis?
Posted: Thu Nov 16, 2023 2:43 pm
jkosharek wrote: ↑Thu Nov 16, 2023 11:11 am
You could put something like (replace RQSALL with the reset command, just use RQSALL for testing) this in a script and have crontab execute it monthly on your NodeLink machine:
{ echo "^^^RQSALL"; sleep 1; } | telnet X.X.X.X 8000
