Help with Solar Channel Setup
SirMaple
Re: Help with Solar Channel Setup
Post by SirMaple » Tue May 02, 2023 7:15 am
ben wrote:
Mon May 01, 2023 1:37 pm
Try
INSERT INTO hourdata (channel_id, date, wattsecond, watt, kwh, seconds, cost, totalcost, amps, peakwatt, minwatt)
SELECT '2386', date, wattsecond, watt, kwh, seconds, cost, totalcost, amps, peakwatt, minwatt
FROM hourdata
WHERE channel_id = 2341
AND date < (select min(date) from hourdata where channel_id = 2386);
That did it. Everything looks good now. Just need to clean up the CT wiring in the garage and I'd say everything is done.
Thanks again for all the help. Much appreciated!
