I'm trying to get GEM to send to a new Home Assistant instance but I'm failing. The data keeps going to the old instance. I can see the data appearing in the old Home Assistant (HA) instance. tcpdump also shows the data being sent there. My current theory: I'm missing a step in telling GEM to use this new URL.
The IP addresses in question are:
old HA: 10.55.0.38
new HA: 10.55.0.72
gem: 10.52.0.71
tcpdump shows:
14:50:31.563015 IP 10.52.0.71.1114 > 10.55.0.38.8000: Flags [P.], seq 88156:88585, ack 1, win 17376, options [nop,nop,TS val 16774323 ecr 109092075], length 429
14:50:31.604971 IP 10.55.0.38.8000 > 10.52.0.71.1114: Flags [.], ack 88585, win 1027, options [nop,nop,TS val 109097075 ecr 16774323], length 0
% telnet 10.55.0.72 8000
Trying 10.55.0.72...
Connected to home-assistant.example.org.
Escape character is '^]'.
telnet> quit
Connection closed.
Serial#: [redacted]
COM firmware ver: 5.39
ENG firmware ver: 1.49
RealTime Status: ON
Packet Send Interval: 5
Pri. Packet Format: 8
Sec. Packet Format: 0
Sys Status: OK
