I have a strange issue that I didn't see an answer for already. Both of the LEDs are rapidly blinking when the unit is rebooted and I cannot connect to it. I suspect the power supply may have failed and is not pushing the correct voltage out but do not have another one handy to test this theory. I also cannot connect to the unit anymore via ethernet. I have unplugged it for a bit but the same condition occurs when replugged.
Can someone shed some light on this LED pattern and what this indicates?
Gem LEDs both green and rapidly blinking
Re: Gem LEDs both green and rapidly blinking
I was able to change out the coin battery and the behaviour is a little different now with the LEDs changing colors on boot but its still not solid per se. rapidly blinking and still cannot connect. The ethernet module also shows no activity lights.
Does your power supply match the one noted at https://www.brultech.com/contact?MrEmbedded wrote: ↑Fri Aug 05, 2022 12:21 pmI was able to change out the coin battery and the behaviour is a little different now with the LEDs changing colors on boot but its still not solid per se. rapidly blinking and still cannot connect. The ethernet module also shows no activity lights.
Yep I have an older 1.5a adapter so that must be the exact issue. I actually found some 2.0a adapters that have the correct barrel dimensions and am waiting for them to arrive. If these don't do the job I'll order one from you directly.
Should work fine just make sure to check all your settings as that old supply can cause some correction.MrEmbedded wrote: ↑Sat Aug 06, 2022 9:36 amYep I have an older 1.5a adapter so that must be the exact issue. I actually found some 2.0a adapters that have the correct barrel dimensions and am waiting for them to arrive. If these don't do the job I'll order one from you directly.
Feel free to email me screenshots of the Adv section to check.
New power supplies arrived today. Back in business.
