Broken Channel
nbsvirginia
Broken Channel
Post by nbsvirginia » Mon Jun 27, 2022 11:17 am
One of my GEM channels seems to be broken. With no CT connected, it constantly shows a load of 960 watts (fluctuating slightly).
Is there a way to fix this? I have tried a full reset of the GEM which did not help.
Re: Broken Channel
Post by ben » Mon Jun 27, 2022 12:23 pm
Check to make sure you don't have any Micro-CTs hooked up like a Split. This will cause bleed to other channels on the GEM.
What's the CT settings on that channel?
nbsvirginia
Re: Broken Channel
Post by nbsvirginia » Mon Jun 27, 2022 1:07 pm
All Micro CT's are connected on the inner two connections (B-Type). Only the S200 and the S100 are connected on the outer ones (A-Type).
It is Channel 3.
Screen Shot 2022-06-27 at 14.01.14.png (37.1 KiB) Viewed 970 times
Re: Broken Channel
Post by ben » Mon Jun 27, 2022 2:35 pm
It is Channel 3.
Try disconnecting CH1/CH2 to see if there's an issue with the burden in one of the Split CTs.
nbsvirginia
Re: Broken Channel
Post by nbsvirginia » Wed Jun 29, 2022 11:48 am
It is Channel 3.
Great catch @ben. Seems the S100 are the cause for the bleeding. I will order new ones.
Re: Broken Channel
Post by ben » Wed Jun 29, 2022 12:17 pm
It is Channel 3.
Try one, then try the other. It would be weird if both are defective. Contact sales(at)brultech.com when you figure it out and let them know you have a defective S100. They should be able to help you out.
