Split30 CT - Type A or Type B?
ltbarkley
Post by ltbarkley » Tue Jun 14, 2022 12:56 pm
The documentation seems to conflict itself:
From https://www.brultech.com/store/index.ph ... tachment=7
Page 13 states "The following CT models are “Type A”: SPLIT-30, SPLIT-60, SPLIT-100, SPLIT-200, SPLIT-400/600, SPLIT-170"
However, the very next page, page 14, states:
"The SPLIT-30 is a “Type B” CT and the connection method for Type B
described above applies.
The only difference is the addition of a capacitor inserted in terminals 1
and 4."
I installed the system like stated on page14, using the capacitor. Is this correct? I seem to be getting accurate results on the individual circuits, but want to be sure.
Re: Split30 CT - Type A or Type B?
Post by ben » Wed Jun 15, 2022 9:33 am
and 4."
Page 14 is correct. You'd get crazy values on the other ports due to them having no burden resistor.
ltbarkley
Post by ltbarkley » Thu Jun 16, 2022 9:28 am
Thank you for the clarification Ben! Setup has been a breeze for the most part. If you can change the docs you may want to update that section.
Post by ben » Thu Jun 16, 2022 12:08 pm
Yeah I'll let Paul know about that.
