Solar
solarricc
Solar
Post by solarricc » Sun Feb 20, 2022 1:14 pm
Hi all,
I have been reading about Solar monitoring and PV and I have a PV System which connects outside of the Main Panel to my Mains.
GEM is installed and I have the 2 Main's CT hooked up to my Main Panel and I have one CT hooked up to my Solar Generation Output (Directly onto the outcoming wires of the Solar Panel array)
What I'm having difficulty is how to set up my Dashbox correctly.Currently it is like this:
Mains
Mains
Solar Breaker
Solar Breaker
Do I have it correct?
The Main Window does not look right
Ricc
MainDisplay
MainDisplay
Thank you all and have a great day
Re: Solar
Post by ben » Tue Feb 22, 2022 10:48 am
- Remove Main from Main A/B, possibly hide those channels also
- Set Main on Main A Gen and Main B Gen
The rest looks good. You might want to hide the non-Gen inverter channel also.
solarricc
Re: Solar
Post by solarricc » Wed Feb 23, 2022 11:27 am
Thank you Ben,
I will try out later and see if it looks better.
Question is why would I need to hide Main A/B?
Re: Solar
Post by ben » Wed Feb 23, 2022 11:50 am
Thank you Ben,
If you're selling back thru your Mains then the Gen channels will show you the net metered values.
solarricc
Re: Solar
Post by solarricc » Wed Feb 23, 2022 1:37 pm
Hi Ben,
Thanks for the clarification.
My System is as follows:
Solar Panel -> Combiner -> Net Metering Meter -> Main House Meter
So, the Solar Panel Generation feeds the Main Meter and my Phase A/B comes into my House Panel as Main A/B.
Basically, if I correctly understand the Solar feeds me and the Energy Company. I want to make sure that I sell the exact amount of Energy produced or used since some Numbers don't line up.
This was also the Main reason I bought a GEM since I can check all my circuits.
Re: Solar
Post by ben » Wed Feb 23, 2022 3:03 pm
Hi Ben,
Gotcha. Yeah, set Main A/B Gen as Main. Those are likely the numbers you'll be wanting to look at overall.
yves386
Contact:
Re: Solar
Post by yves386 » Tue Mar 29, 2022 9:44 am
Does anyone know what the accuracy of the Solar PV Monitoring application is?
visit our solar website at https://universalsolarlasvegas.com
Re: Solar
Post by ben » Tue Mar 29, 2022 10:51 am
By spec:
GEM accuracy is at worst 1%.
Split-CTs are at worst 1%.
Micro-CTs are at worst 3%.
In our tests, accuracy usually at worst is around 1.5% (on devices with poor power factor).
