GEM data error - values truncation?
We recently installed our GEM and started logging data every 15 seconds via HTTP GET.
Reviewing our logs we find intermittent errors in values where one or two digits seem to be missing from an otherwise consistently populated value.
Below is an example of log data highlighting two examples bad values interspersed with consistent (and presumably accurate) values.
Any suggestions for the possible cause or fix?
Re: GEM data error - values truncation?
What COM firmware is the GEM running?jbai wrote: ↑Fri Feb 04, 2022 1:16 pmWe recently installed our GEM and started logging data every 15 seconds via HTTP GET.
COM firmware ver: 5.23
ENG firmware ver: 1.49
RealTime Status: ON
Packet Send Interval: 15
Pri. Packet Format: 3
Sec. Packet Format: 0
Sys Status: OK
RealTime Status: ON
Sys Status: OK
Give COM 5.39 a try (issue in the thread isn't related but has upgrade instructions) https://brultech.com/community/viewtopic.php?f=3&t=2220
We had another customer with similar HTTP Get issues that Paul patched. It may solve the issue.
Thank you, Ben. We updated the firmware to v5.39 but the issue persists.
We also appear to have at least one record pulled with an incorrect channel assignment or something.
The flagged meter reading below lines up better with other channels, and is shares the timestamp with a valid entry for this channel (see last screenshot below).
Please let us know if you have any troubleshooting guidance. We are concurrently assessing our data polling code & methods for possible errors.
- gem-data-error-truncation-2022-02-11.jpg (193.7 KiB) Viewed 1064 times
- GEM-data-error-truncation-2-2022-02-11.jpg (190.84 KiB) Viewed 1064 times
- GEM-Data-error-wrong-channel-2022-02-11.jpg (152.56 KiB) Viewed 1064 times
Can you send your Status Page on the GEM?jbai wrote: ↑Fri Feb 11, 2022 1:38 pmThank you, Ben. We updated the firmware to v5.39 but the issue persists.
Screenshot of our current GEM status page:
- GEM-setup-20220212.jpg (371.43 KiB) Viewed 1050 times
Trying to simulate it here, what type of server are you sending to?
While we're trying to get it to act up, can you try dropping both COM1 Baud and the baud on the WiFi/Ethernet module to 19200? Wondering if it's a buffer issue.
- In the GEM Setup Webpage under Adv you can change the baud rate GEM-side. Do this first.
- Then on the WiFi/Ethernet Port 80 config page you can change the baud under Application Setup.
Thank you, Ben. A colleague or I will post updates/questions in the coming days as we dig into this and collect data.
To answer your prior question, our GEM data is being sent to an Apache/mod_wsgi server on Ubuntu 20 on an Oracle cloud VM.
