I'm waiting for the electricians to arrive. While doing a house-rewire, they will set up the CTs in the new panel.
My main concern is where to place the GEM relative to the new electrical panel. I'm thinking below. But would the side also work. This will be a 200A panel with about 28 initial circuits.
If I need to extend the CT wires a couple of feed, I can solder on some wire. Is that feasible?
Thank you
pre-install - concerned about CT wire length & placement
Re: pre-install - concerned about CT wire length & placement
Placement is up-to-you. It just can't be within the panel. You can look over the other installs on the forums (under Projects) for some ideas.dvl wrote: ↑Fri Feb 04, 2022 9:54 amI'm waiting for the electricians to arrive. While doing a house-rewire, they will set up the CTs in the new panel.
Thank you
Extending is possible. If at a longer distance use CAT cable to reduce the amount of possible interference.
Looking at this project in the projects forum alleviates my fear about side placement. There seems to be a junction box below the GEM for longer cables.
For others, like me, wondering about this, here's what I found:
Another side mount solution.
and another
bottom left corner of panel
and another
