deepb
Post
by deepb » Fri Dec 10, 2021 9:03 am
Hello,
I am trying to us btmon to post to MQTT.
I got btmon from here:
https://github.com/BenK22/mtools/blob/i ... /btmon3.py
My config:
[source]
device_type = gem
ip_read = true
ip_host = 10.0.0.6
ip_port = 80
ip_mode = client
ip_poll_interval = 5
[mqtt]
mqtt_out = true
mqtt_upload_period = 5
mqtt_host = 127.0.0.1
mqtt_clientid = btmon-gem1
When I start btmon with
python3 btmon3.py --ip --ip-mode=client --ip-host=10.0.0.6 --ip-port=80 --print --device-type=gem
I get an output that looks alright:
root@openhab:~/btmon# python3 btmon3.py --ip --ip-mode=client --ip-host=10.0.0.6 --ip-port=80 --print --device-type=gem
2021/12/10 15:01:51 btmon: 4.0.0
2021/12/10 15:01:51 python: 3.9.2 (default, Feb 28 2021, 17:03:44)
[GCC 10.2.1 20210110]
2021/12/10 15:01:51 platform: linux
2021/12/10 15:01:51 device type: gem
2021/12/10 15:01:51 device list: ['']
2021/12/10 15:01:51 packet format: gem48ptbin
2021/12/10 15:01:51 schema: counters
2021/12/10 15:01:51 SOCKET: timeout: 60
2021/12/10 15:01:51 SOCKET: server host: 10.0.0.6
2021/12/10 15:01:51 SOCKET: server port: 80
2021/12/10 15:01:59: Serial: 01011343
2021/12/10 15:01:59: Voltage: 241.80V
2021/12/10 15:01:59: Ch01: -128.619799KWh ( 54W)
2021/12/10 15:01:59: Ch02: -326.071099KWh ( 68W)
2021/12/10 15:01:59: Ch03: -488.204104KWh ( 272W)
2021/12/10 15:01:59: Ch04: 0.328359KWh ( 8W)
2021/12/10 15:01:59: Ch05: -0.002141KWh ( 0W)
2021/12/10 15:01:59: Ch06: -0.002517KWh ( 0W)
2021/12/10 15:01:59: Ch07: -0.000008KWh ( 0W)
2021/12/10 15:01:59: Ch08: -0.000216KWh ( 0W)
2021/12/10 15:01:59: Ch09: -143.683807KWh ( 68W)
2021/12/10 15:01:59: Ch10: -468.186038KWh ( 214W)
2021/12/10 15:01:59: Ch11: -10.443799KWh ( 0W)
2021/12/10 15:01:59: Ch12: -0.000008KWh ( 0W)
2021/12/10 15:01:59: Ch13: -0.000006KWh ( 0W)
2021/12/10 15:01:59: Ch14: -0.009339KWh ( 0W)
2021/12/10 15:01:59: Ch15: -0.000004KWh ( 0W)
2021/12/10 15:01:59: Ch16: -0.000006KWh ( 0W)
2021/12/10 15:01:59: Ch17: -0.000004KWh ( 0W)
2021/12/10 15:01:59: Ch18: -0.001485KWh ( 0W)
2021/12/10 15:01:59: Ch19: -0.000005KWh ( 0W)
2021/12/10 15:01:59: Ch20: -0.000061KWh ( 0W)
2021/12/10 15:01:59: Ch21: -0.000010KWh ( 0W)
2021/12/10 15:01:59: Ch22: -0.000063KWh ( 0W)
2021/12/10 15:01:59: Ch23: -0.000008KWh ( 0W)
2021/12/10 15:01:59: Ch24: -0.000009KWh ( 0W)
2021/12/10 15:01:59: Ch25: -0.000004KWh ( 0W)
2021/12/10 15:01:59: Ch26: -0.000124KWh ( 0W)
2021/12/10 15:01:59: Ch27: -0.000008KWh ( 0W)
2021/12/10 15:01:59: Ch28: -0.000015KWh ( 0W)
2021/12/10 15:01:59: Ch29: -0.000005KWh ( 0W)
2021/12/10 15:01:59: Ch30: -0.000063KWh ( 0W)
2021/12/10 15:01:59: Ch31: -0.000007KWh ( 0W)
2021/12/10 15:01:59: Ch32: -0.004349KWh ( 0W)
2021/12/10 15:01:59: p1: 0
2021/12/10 15:01:59: p2: 0
2021/12/10 15:01:59: p3: 0
2021/12/10 15:01:59: p4: 0
2021/12/10 15:01:59: t1: 0.000000
2021/12/10 15:01:59: t2: 0.000000
2021/12/10 15:01:59: t3: 0.000000
2021/12/10 15:01:59: t4: 0.000000
2021/12/10 15:01:59: t5: 0.000000
2021/12/10 15:01:59: t6: 0.000000
2021/12/10 15:01:59: t7: 0.000000
2021/12/10 15:01:59: t8: 0.000000
However when I run it with
to post to MQTT I get the following:
2021/12/10 15:03:08 btmon: 4.0.0
2021/12/10 15:03:08 python: 3.9.2 (default, Feb 28 2021, 17:03:44)
2021/12/10 15:03:08 platform: linux
2021/12/10 15:03:08 device type: gem
2021/12/10 15:03:08 device list: ['']
2021/12/10 15:03:08 packet format: gem48ptbin
2021/12/10 15:03:08 schema: counters
2021/12/10 15:03:08 SOCKET: timeout: 60
2021/12/10 15:03:08 SOCKET: server host: 10.0.0.6
2021/12/10 15:03:08 SOCKET: server port: 80
2021/12/10 15:03:08 SOCKET: poll interval: 5
2021/12/10 15:03:08 MQTT: mqtt:127.0.0.1:1883?clientid=btmon-gem1
2021/12/10 15:03:08 MQTT: user: <not-specified>
2021/12/10 15:03:08 MQTT: tls: <not-specified>
2021/12/10 15:03:08 MQTT: topic: /house/energy
2021/12/10 15:03:08 MQTT: qos: 0
2021/12/10 15:03:08 MQTT: retain: False
2021/12/10 15:03:08 MQTT: will: <not-specified>
2021/12/10 15:03:08 MQTT: upload period: 5
2021/12/10 15:03:08 MQTT: map:
2021/12/10 15:03:19 Exception in MQTTProcessor: 'ch1_a'
Any Ideas how to proceed?
thanks
Daniel
Post
by ben » Fri Dec 10, 2021 10:57 am
deepb wrote: ↑Fri Dec 10, 2021 9:03 am
Hello,
My config:
[source]
device_type = gem
ip_read = true
ip_host = 10.0.0.6
ip_port = 80
ip_mode = client
[mqtt]
mqtt_out = true
thanks
Daniel
I think you need to switch the db_schema, try
db_schema = ecmreadext
deepb
Post
by deepb » Fri Dec 10, 2021 4:43 pm
unfortunately same error.
root@openhab:~/btmon# python3 btmon3.py -c config.cfg
2021/12/10 22:42:14 btmon: 4.0.0
2021/12/10 22:42:14 python: 3.9.2 (default, Feb 28 2021, 17:03:44)
2021/12/10 22:42:14 platform: linux
2021/12/10 22:42:14 device type: gem
2021/12/10 22:42:14 device list: ['']
2021/12/10 22:42:14 packet format: gem48ptbin
2021/12/10 22:42:14 schema: ecmreadext
2021/12/10 22:42:14 SOCKET: timeout: 60
2021/12/10 22:42:14 SOCKET: server host: 10.0.0.6
2021/12/10 22:42:14 SOCKET: server port: 80
2021/12/10 22:42:14 SOCKET: poll interval: 5
2021/12/10 22:42:14 MQTT: mqtt:127.0.0.1:1883?clientid=btmon-gem1
2021/12/10 22:42:14 MQTT: user: <not-specified>
2021/12/10 22:42:14 MQTT: tls: <not-specified>
2021/12/10 22:42:14 MQTT: topic: /house/energy
2021/12/10 22:42:14 MQTT: qos: 0
2021/12/10 22:42:14 MQTT: retain: False
2021/12/10 22:42:14 MQTT: will: <not-specified>
2021/12/10 22:42:14 MQTT: upload period: 5
2021/12/10 22:42:14 MQTT: map:
2021/12/10 22:42:29 Exception in MQTTProcessor: 'ch1_a'
note that btmon is still running, but the exception is thrown every few seconds.
Post
by ben » Mon Dec 13, 2021 11:20 am
deepb wrote: ↑Fri Dec 10, 2021 4:43 pm
Can you check the GEM Setup Webpage under Packet Send and make sure "Include Current in Packet" is enabled?
deepb
Post
by deepb » Tue Dec 14, 2021 5:28 am
Hello,
it was off.
I enabled it. Just to be sure i restarted COM and ENG. However I get the same error.
thanks
Daniel
Post
by ben » Tue Dec 14, 2021 10:46 am
deepb wrote: ↑Tue Dec 14, 2021 5:28 am
Hello,
it was off.
thanks
Daniel
Alright, run it with --debug enabled, maybe it'll give some more insight as I'm not sure.
deepb
Post
by deepb » Tue Dec 14, 2021 1:02 pm
well that looks more interesting...
2021/12/14 19:01:10 btmon: 4.0.0
2021/12/14 19:01:10 python: 3.9.2 (default, Feb 28 2021, 17:03:44)
2021/12/14 19:01:10 platform: linux
2021/12/14 19:01:10 device type: gem
2021/12/14 19:01:10 device list: ['']
2021/12/14 19:01:10 packet format: gem48ptbin
2021/12/14 19:01:10 schema: ecmreadext
2021/12/14 19:01:10 buffer size: 120
2021/12/14 19:01:10 SOCKET: timeout: 60
2021/12/14 19:01:10 SOCKET: server host: 10.0.0.6
2021/12/14 19:01:10 SOCKET: server port: 80
2021/12/14 19:01:10 SOCKET: poll interval: 5
2021/12/14 19:01:10 MQTT: mqtt:127.0.0.1:1883?clientid=btmon-gem1
2021/12/14 19:01:10 MQTT: user: <not-specified>
2021/12/14 19:01:10 MQTT: tls: <not-specified>
2021/12/14 19:01:10 MQTT: topic: /house/energy
2021/12/14 19:01:10 MQTT: qos: 0
2021/12/14 19:01:10 MQTT: retain: False
2021/12/14 19:01:10 MQTT: will: <not-specified>
2021/12/14 19:01:10 MQTT: upload period: 5
2021/12/14 19:01:10 MQTT: map:
2021/12/14 19:01:10 packet format is GEM48PTBinaryPacket
2021/12/14 19:01:10 using collector PollingSocketClientCollector
2021/12/14 19:01:10 using 1 processors:
2021/12/14 19:01:10 MQTTProcessor
2021/12/14 19:01:10 setup PollingSocketClientCollector
2021/12/14 19:01:10 setup MQTTProcessor
2021/12/14 19:01:10 SOCKET: waiting for 5 seconds
2021/12/14 19:01:15 opening socket connection to 10.0.0.6:80
2021/12/14 19:01:18 sending request 1 to device
2021/12/14 19:01:18 SOCKET: sending ^^^APISPK
2021/12/14 19:01:18 waiting for data from device
2021/12/14 19:01:18 reading 1 of 1 packets
2021/12/14 19:01:19 adding buffer for 01011343
2021/12/14 19:01:19 buffering packet ts:1639504879 sn:01011343
2021/12/14 19:01:19 closing socket connection
2021/12/14 19:01:19 buffer info:
2021/12/14 19:01:19 01011343: 1 of 120 (1639504879)
2021/12/14 19:01:19 processing with MQTTProcessor
2021/12/14 19:01:19 not enough data for 01011343
2021/12/14 19:01:19 SOCKET: waiting for 5 seconds
2021/12/14 19:01:24 opening socket connection to 10.0.0.6:80
however I get this thrown error:
File "/root/btmon/btmon3.py", line 2249, in process
p.process_compiled(self.packet_collector.packet_buffer)
File "/root/btmon/btmon3.py", line 2838, in process_compiled
self.process_calculated(packets)
File "/root/btmon/btmon3.py", line 4214, in process_calculated
self._add_msg(p, c, p[c])
KeyError: 'ch1_a'
KeyError: 'ch1_a'
Post
by ben » Tue Dec 14, 2021 3:38 pm
It looks like
Needs to be added to your cfg file.
Post
by ben » Tue Dec 14, 2021 4:38 pm
Applied a fix to the script itself. The addition I made to include current in MQTT wasn't checking the conditional to see if it should be included.
deepb
Post
by deepb » Wed Dec 15, 2021 10:42 am
now it works, thanks!
