I installed my GEM yesterday, and got things setup and working with the Dashbox. I had only setup four channels in order to test the setup and make sure everything was working, and today I went to setup the rest. However, I cannot connect to the GEM, despite it still sending data to the Dashbox. I've tried in the browser as well as with the GEM Network Utility. My Dashbox and GEM are connected via ethernet (I have ethernet-only module in the GEM) on the same subnet (10.117.0.0/23).
Strangely, I can change the IP address of the GEM with the GEM Network Utility (Save Settings appears to work when I toggle between DHCP and Static), but I cannot open the connection to the GEM via the utility or the browser in order to update channel data.
I've read over the manual and done the F1-F3 functions, and that did not appear to change anything, unfortunately. I've also disabled Window firewall entirely to verify that was not an issue.
GEM Sending Data to Dashbox, but Unable to Connect to it
Re: GEM Sending Data to Dashbox, but Unable to Connect to it
What mode is the Ethernet module in (Mixed, Server, or Client) and what's your Idle Time set to?sdwilsh wrote: ↑Mon Sep 06, 2021 1:06 pmI installed my GEM yesterday, and got things setup and working with the Dashbox. I had only setup four channels in order to test the setup and make sure everything was working, and today I went to setup the rest. However, I cannot connect to the GEM, despite it still sending data to the Dashbox. I've tried in the browser as well as with the GEM Network Utility. My Dashbox and GEM are connected via ethernet (I have ethernet-only module in the GEM) on the same subnet (10.117.0.0/23).
It was set to mixed. I changed the "Comm Setting" "Idle Time" from 8 to 5, and was able to get access again, although I don't know if that actually fixed it or something else caused it.
Regardless, I have access now, and have gotten things setup.
The Idle Time setting basically means after having a connection for X seconds then disconnect. So if your Idle Time is greater then your Packet Send Interval it'll never close the Client connection to allow a Server connection.
They both would have been set to 8 then, since the dashbox wants the HTTP GET every 8 seconds per the documentation I was reading.
Yeah, that would cause that issue, you should be good now.
