I can not be the first to request this, but here it is anyway. On the Live Data Page display can you possibly add the "Channel" name in the blank columns in front of the Channel number? As I am suffering from "Lack of Youth" I have to really think about what each channel is reporting.... OK, I am tired of trying to locate my "Cheat-Sheet" that the above mentioned disability keeps me from locating. The names are already in the dB, well that is if it was entered, which in my case it was.
It should not be that difficult as I am not asking for a small gif showing the clothes spinning in a front load dryer or a pot of soup boiling with steam coming out of the pot on top of a stove... but do not count that thought out as someone may ask for it.
That second item in Ben Franklin's quote below is getting to be a pain with this "Lack of Youth" crap
GEM Network Utility - Live Data Page request
Don
Benjamin Franklin
Benjamin Franklin
Re: GEM Network Utility - Live Data Page request
The Live Data on the GEM Network Utility just polls the GEM directly, it has no interaction with the DashBox.Mustang65 wrote: ↑Fri Aug 06, 2021 1:03 pmI can not be the first to request this, but here it is anyway. On the Live Data Page display can you possibly add the "Channel" name in the blank columns in front of the Channel number? As I am suffering from "Lack of Youth" I have to really think about what each channel is reporting.... OK, I am tired of trying to locate my "Cheat-Sheet" that the above mentioned disability keeps me from locating. The names are already in the dB, well that is if it was entered, which in my case it was.
How is your GEM connected to the DashBox? If you're using the latest F/W on there, the "Live Data" button in the Settings section basically does the same thing. I can likely expand this to work with WiFi/Ethernet and/or Ethernet devices. I just need a good way to figure out what port it's listening over (8000 is the default).
