GEM with Ethernet no longer responding?
ejosterberg
Post by ejosterberg » Wed Dec 09, 2020 7:50 am
Hello,
I have a GEM with hardwired Ethernet, configured with an assigned (static lease) DHCP address, which no longer provides data via the btmon script. My script was connecting to the GEM on port 80.
The GEM is responding to ping and using nmap, the only listening port is 1461.
I'm remote and would like to know if there's any options to bring it back online remotely and what can be done to understand what happened to it and prevent future data-loss and interruption to monitoring?
[root@msphass bin]# ping 10.32.150.208
PING 10.32.150.208 (10.32.150.208) 56(84) bytes of data.
64 bytes from 10.32.150.208: icmp_seq=1 ttl=128 time=0.265 ms
64 bytes from 10.32.150.208: icmp_seq=2 ttl=128 time=0.366 ms
64 bytes from 10.32.150.208: icmp_seq=3 ttl=128 time=0.417 ms
^C
--- 10.32.150.208 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 0.265/0.349/0.417/0.064 ms
[root@msphass bin]# nmap 10.32.150.208
Starting Nmap 6.40 ( http://nmap.org ) at 2020-12-09 06:28 CST
Nmap scan report for 10.32.150.208
Host is up (0.00013s latency).
Not shown: 999 closed ports
PORT     STATE SERVICE
1461/tcp open  ibm_wrless_lan
MAC Address: 00:08:DC:15:99:06 (Wiznet)
Nmap done: 1 IP address (1 host up) scanned in 3.57 seconds
Re: GEM with Ethernet no longer responding?
Post by ben » Wed Dec 09, 2020 3:05 pm
Hello,
^C
PORT     STATE SERVICE
Shutdown btmon.py and see if you can pull the GEM Setup Webpage (or try grabbing settings via btcfg.py http://lancet.mit.edu/mwall/projects/po ... n/btcfg.py).
ejosterberg
Post by ejosterberg » Thu Dec 10, 2020 10:21 pm
does not respond to a browser or nmap. btmon was disabled for 4 hours, no change.
Post by ben » Fri Dec 11, 2020 10:51 am
When was it purchased? Wondering if it has one of the old power supplies as per the notice at: https://www.brultech.com/contact.
Have you ever updated the F/W on the unit?
ejosterberg
Post by ejosterberg » Sat Dec 19, 2020 6:46 am
It's <2 months old. No updates applied. It was installed 4 days after being received.
Post by ben » Mon Dec 21, 2020 11:38 am
Can you try opening http://10.32.150.208/ in any web browser to see if you pick up the GEM page.
Given 1461 is open can you try the GEM Network Utility to see if you can pick up the module? 1461 is used to program the module.
Set a statc IP if so.
