GEM /DB channel question
bgrubb1
Post by bgrubb1 » Sun Oct 18, 2020 6:07 pm
I have wired some solar into my Pool pump circuit. It's not on a circuit where I can call it net or main since it normally draws more power than the solar provides. It "appears" that in my current config. when the solar produces, when I hit the point that the circuit goes negative (solar producing more than pump consuming) the DB reading goes to near zero, then starts showing the negative power as positive consumption. Have tried experimenting with DB and Gem channel settings and no joy. Is there a way to configure a "normal" channel to display its negative reading ??
...Barry
Re: GEM /DB channel question
Post by ben » Mon Oct 19, 2020 10:11 am
...Barry
If it has a chance of going negative it has to be set to NET. It'll show up normally when not producing more then it's consuming.
Needs to be a NET channel to show negative. Normal channels don't take the polarized counter into consideration.
bgrubb1
Post by bgrubb1 » Mon Oct 19, 2020 1:56 pm
so both the GEM and DB set to net ?
Post by ben » Mon Oct 19, 2020 2:00 pm
Yeah, try that.
bgrubb1
Post by bgrubb1 » Tue Oct 20, 2020 1:38 pm
That worked, Thank You Ben
