GEM PT measurement
Posted: Fri Sep 18, 2020 8:41 pm
by bgrubb1
About every 2 weeks, my Gem reports my AC voltage is around 240V until I unplug it and replug
I have cleaned the contacts, no joy
Any ideas out there ??
...Barry
Re: GEM PT measurement
Posted: Mon Sep 21, 2020 10:26 am
bgrubb1 wrote: ↑Fri Sep 18, 2020 8:41 pm
...Barry
So it's basically doubling the voltage? Does it happen gradually or does it go straight to 240V? Do your other readings jump to double the value?
This probably isn't the issue but make sure the PT plug is plugged all the way in, you can cause a short if the plug isn't snapped in all the way.
Can you try going into Channel Option and re-saving the PT settings? The only other way I can see this happening is if for some reason it's pulling the wrong PT Range from memory.
EDIT: What COM F/W is the GEM running?
Posted: Mon Sep 21, 2020 4:34 pm
by bgrubb1
Periodically the voltage the GEM sees just goes up to ~220V unplugging PT from wall and re-plugging doesn't change it. replugging PT from GEM brings it back to normal See attached
...Barry Oh and yes All channels essentially double
Posted: Tue Sep 22, 2020 1:02 pm
bgrubb1 wrote: ↑Mon Sep 21, 2020 4:34 pm
Let me know the COM version, it does sound like your PT Range is getting messed up.
Posted: Tue Sep 22, 2020 7:16 pm
by bgrubb1
Ben See below
...Barry
Posted: Wed Sep 23, 2020 11:31 am
Try bumping the COM firmware to the 5.XX series, you can download it below:
http://brultech.com/software/files/checksn/3/1
Posted: Thu Oct 01, 2020 1:47 pm
by bgrubb1
Just to update
I upgraded the com firmware no change
The next time i went X2 i just move the PT cable near the GEM and it corrected
Maybe the bend of the cable ?? It has been accurate for 3 days now
...Barry
Posted: Thu Oct 01, 2020 1:58 pm
Barry,
For good measure I would clean the male pin connector with alcohol. Then using a thin Q-Tip gently wipe inside of the female barrel jack.
A quick shot of canned air to insure no fibres are left behind. If you wiggle the radio jack and observe the spike it’s more than likely the port. If you bend any length of cable while the jack is firmly in place that points to a break in the cable.
