GEM showing 0W
GEM showing 0W
I am showing amperage on several channels but no watts. Watts reads as 0. Attached as screen grab of the Live Data window. (Before you ask, I have only thus far fed wires through the top hole in the back of my GEM, so that is why there are gaps in the numbering.
- 0 Watts.png (23.93 KiB) Viewed 1262 times
Re: GEM showing 0W
Doh, figured it out. Needed the PT lead plugged in as well. SO that looks like there are 3 power bricks for this setup to function.
Re: GEM showing 0W
Yeah there's 2 for the GEM, one for the DashBox.ralbrightii wrote:Doh, figured it out. Needed the PT lead plugged in as well. SO that looks like there are 3 power bricks for this setup to function.
We used a single supply setup with our ECM-1240, the issue with that setup is the additional power draw of WiFi/Ethernet/etc. can affect voltage readings (especially WiFi due to the difference between transmit and receive power).
