Is there any documentation on how to setup multiple one wire bus temperature sensors?
When looking online it looks like I may need a resistor. Is that correct?
Any recommendations on how to cable up two or more temperature sensors to the connector on the GEM?
Thanks for your help.
Carl
One Wire Bus Temperature Sensor Questions
Re: One Wire Bus Temperature Sensor Questions
There is a document at Brultech.com (Support) called GEM Quick Guide. It has a diagram of how to wire up the temperature 1-wire sensors (Page 6 or 7). There are also other more detailed guides for GEM which describe how to configure the sensors within the GEM once wired. Hope this helps.
I used terminal blocks to wire the sensors into the GEM. I went this route to ensure if maintenance or replacement was required it could be done with out impact to other existing 1 wire sensors on the network.
Teken, I also used a terminal block for my temp sensors. Since this is technically a star topology, based on the 1-wire spec shouldn't I be using 100 ohm resisters on all the legs except for the longest run?
I've never needed to add in a resistor into the 1 wire network for any of the systems I have. I currently have four active systems two are the dual GEM's. Which provide sixteen 1 wire sensors. The other is from a dual Autelis Bridge system which provides (64) 1 wire sensors.kewlwinter wrote:Teken, I also used a terminal block for my temp sensors. Since this is technically a star topology, based on the 1-wire spec shouldn't I be using 100 ohm resisters on all the legs except for the longest run?
A fifth system is currently under rework and development for a long term project for fire & electrical safety monitoring. That array has 30 something sensors in that system for a total once all of them are online will offer me: 110 sensors
